what oil do you use in the vq??
i know this is a hashed over question, but i have to ask it again, i have been using wolfs head 5 or 10 w30 as i find the old girl seems to love it. she runs quiet and seems to idle smoother imo. i will put a oem filter on as well when i remember.
I bought my Maxima in 2006. It had 100k on it.
I found a couple of receipts in it for Mobile One
Synthetic.
I have continued use of synthetic oil. Either. Mobil One or O Reilys. Usually 5-30, sometimes 10-30. My car is generally used on the highway.
My oil change interval is around 6000-8000 miles.
My car has about 215k on it now.
My engine still has good compression.
I removed the lower oil pan when I replaced my water pump at about 200k. I saw no sludge or deposits at all. Just a very clean engine.
Synthetic.
Typically, a synthetic will flow similar to a conventional of the lower specification ... meaning, when hot a 40 weight synthetic will flow similar to a 30 weight conventional.
If you choose your [x]W-40 wisely, there should be no down-side.
I have found that my mileage using a 10W-30 (synthetic or conventional) as opposed to the 5W-40 (synthetic) doesn't change in the least.
I used to use 5w-30 Mobil One full synthetic. I put 7,000 a year at most so only 2 oil changes a year. I removed the valve covers for a 00VI swap and did not like what I saw at 136k. It was very dirty inside compared to the much higher milage donor DEK. It got me thinking.
I switched to Pennzoil conventional, either regular or high milage, for all my vehicles. I can't say if it made a difference on the inside. At least I save a few dollars. With what little miles I put on my vehicles I should just change it every 3 months.
BBmaxi
41
01-02-2019 12:54 PM
Kawowski
18
06-15-2013 06:18 PM
4togrfr
01-20-2007 10:02 PM
97Se5spd
121
10-15-2006 07:33 PM
