Anyone ever replaced a belt tensioner?
Old 06-05-2018, 08:21 PM
hooloovoo's Avatar
Pretty sure ours is broke, it doesn't tighten the belt at all. I'm going to try a slightly shorter belt (found one that is 0.4" shorter) and see if I can just put weight on it while someone else locks the nut in place but failing that, I'm wondering how bad it is to replace. I can find like zero info about doing it anywhere which makes me think it's bad...
hooloovoo is offline
Old 06-05-2018, 08:54 PM
I'm nutty for Nissans
JSutter's Avatar
It's easy really. There are 3 bolts that mount it to the engine. You may need to remove the pulley to get to all 3 bolts. There isn't a huge amount of room to work is the hard part. A ratcheting wrench might help.
JSutter is offline
Old 06-06-2018, 12:41 PM
reallywildstuff's Avatar
this is called the "idler pulley" - you're not finding any info because you're searching for the wrong term
https://maxima.org/forums/4th-genera...lley-woes.html
maximum force should not be required, two people should not be required.
it's supposed to fit together like a sewing machine - if it doesn't, something is seriously wrong
reallywildstuff is offline
Old 06-12-2018, 09:36 PM
Quickywd01's Avatar
Quickywd01 is offline
Old 06-16-2018, 08:26 AM
hooloovoo's Avatar
Well I ended up giving in to my son's whining and taking it to a shop to have the A/C compressor replaced (that hurt $$$$). I just had them replace the idler pulley, they only charged $60 to do it. I thought about doing it myself but looking at the replacement options it was hard to tell which were just the pulley and which had the tensioner assembly included (and some of the reviews noted that even ones pictured with the bolt didn't actually include it), so I figured I'd let them figure it out with the compressor.
BobMax
06-05-2006 05:23 AM
zboy
06-09-2004 06:57 PM
maxima_rob
12-02-2003 08:52 AM
TonyGotSkilz
08-20-2003 02:51 PM
stose95
08-06-2003 08:30 PM
Quick Reply: Anyone ever replaced a belt tensioner?
