Antitheft
Antitheft
Girlfriend had front end collision and triggered Anti theft. Followed fsm and power to 3 on relay then none to starter signal wire. 98 gxe
Well Dennis I know it's been 7 years but you did write this
My car has a manufacturing date of 98 and it had NATs, easiest way to tell is looking to see if your key has the chip.
If I read the wiring diagram correctly, remove the theft warning relay and put a jumper in across pins 3 and 4. The THEFT WARNING relay is by the power steering reservoir on the right side of the car. The cover over the relays is labeled as to which relay is which. The cover is labeled ANTI-THEFT.
This will allow the starter to crank the engine IF the alarm system is the cause. I'm pretty sure that the security led in with the clock will be on If the alarm system is the cause.
