Digital clock connection loose?
The cars vibration eventually breaks the solder joints. This is a well known issue in the speedo and tach. Heating the existing solder joints until the solder turns into a liquid state restores electrical function.
I've fixed the speedo on outhe car as well as the clock on a Toyota this way.
Remove the clock. Remove it's rear cover to expose the electronics. Heat the solder. Reassemble.
This probably takes less time than any other method. It is also a free fix.
