98 maxima heater core replacement
Old 11-16-2018, 10:26 AM
josemax's Avatar
Does anyone have instructions with pics on how to replace a heater core? Thanks
josemax is offline
Old 11-16-2018, 02:10 PM
JvG
JvG's Avatar
Please look for the Search button on this forum
Someone milusthave had this issue in the past
The problem seems to be uncommon.
JvG is offline
Old 11-16-2018, 02:12 PM
Fakie J Farkerton's Avatar
Are you sure you need a whole new heater core?
If it's just the plastic pieces that go through the firewall that broke, you can buy this from the dealer for about $35 a pop..much easier and cheaper than a new core
Fakie J Farkerton is offline
Old 11-16-2018, 02:44 PM
josemax's Avatar
Thanks guys, I searched for a thread with pics but got nothing. I am going to water test it tomorrow to see if I can find the leak. Hopefully it's one of the plastic hoses, if not I guess I'll have my hands full for a couple of hours
josemax is offline
Old 11-16-2018, 03:56 PM
Rit
Rit's Avatar
I did mine several years ago. It was really a 1st class pain in the A$$. I believe that I used the FSM as a step-by-step procedure. Make sure that you label all of your wire connectors and hoses as you proceed, or you will be doing it again when something doesn't work.
The "funny thing" is that I wound up not putting in the new one. When I looked at the factory one, I could not see any issues with it, and re-installed it. Oddly enough, it never leaked again, and it still going strong on my '98. Unless you are in a warm climate, I would try to delay the job until next Spring. You will have to pull the whole dashboard out.
I still have over 20 photos that I took along the way. If you show me how to store them someplace for you, I will do it. Email me.
Richard.Szczepanski@yahoo.com
Rit is offline
Old 11-17-2018, 04:10 AM
Turbobink's Avatar
Spend $24.00 ... this will assist you related many projects including a heater core replacement.
Turbobink is offline
Old 11-17-2018, 04:44 AM
Rit
Rit's Avatar
Spend zero, and download the FSM. Cheaper, and better.
Rit is offline
Old 11-17-2018, 05:43 AM
Turbobink's Avatar
Agreed, however I’ve found that with some more complex repairs/replacements the FSM will not incorporate common shortcuts and time and effort savers.
For example, there’s truly no need to discharge the AC system and remove the AC compressor in order to replace an alternator.
sonicii
10-27-2010 06:00 PM
michaels'max
29
10-25-2005 10:22 PM
michaels'max
30
09-30-2005 09:00 AM
Quick Reply: 98 maxima heater core replacement
