Sunroof problem 4th gen maxima
1 Attachment(s)
Hello everyone. Hope you can help me. My 98 nissan maxima has a working sunroof. Nothing is wrong with it, goes up and down and opens and closes. The only problem is it has a burning smell that just recently started. Smells like it is coming from the motor but i opened the little pannel up and it works perfectly fine. Just has a strange burning smell. Is there a fuse for the sunroof? Or any other problem that can cause it please help. |
Sounds like your S/R motor is going. Start saving your pennies, or visiting some salvage yards.
Originally Posted by Rit
(Post 9189233)
Does it sound slower than usual?
And especially when it is particularly cold outside? Chances are that the old grease has dried up. That causes it to get sticky. The sticky greasee in turn causes the motor to work hard and get hot. Which causes the smell. The smell is the insulation on the wires to start burning up You could clean the old grease off, then replace with fresh grease. |
Originally Posted by JvG
(Post 9189251)
(Post 9189251)
I would use white lithium grease.
Other members might have other suggestions. I usually use kerosene as a solvent to disolve grease. Other degreasers could work as well. The concept is to remove the old sticky grease which might also have imbeded grit and grime. |
(Post 9189276)
© 2024 MH Sub I, LLC dba Internet Brands
