95 Maxima starts then dies - Maxima Forums
Old 01-06-2019, 01:55 PM
As stated wife went out today and started our 95 Max and it started then died three times.She moved it and took our Camry being afraid of being stranded.When she came back from the store she put the Camry in the garage,started the Max and it was fine.Have three cels egr valve,knock sensor and front O2 sensor but had them all with no problems for a year.
Frank50e is offline
Old 01-06-2019, 02:16 PM
JvG
Perhaps the idle speed is too low due to the issues you don't seem to want to fix.
Low idle speed leads to stalling.
the egr and oxy sensor issues are causing excessive fuel consumption . You are probably getting lower mileage than it could. This costs you $$!
JvG is offline
Old 01-07-2019, 12:10 AM
The only things i can think of is when i started my car one time and it started fine but died right away. Later got it diagnosed i had bad battery and alternator. Never had that problem again until a few months later, my car wouldnt start at all would make a weird noise and wouldnt turn over. Found to be the battery cable. Ever since i replaced those things its good as new. Try checking battery and alternator it could be the alt...
dbaray is offline
Old 01-07-2019, 06:30 AM
Clean the idle air control valve and throttle body.
You should really replace the O2 and knock sensor. EGR I would just get rid of.
ChrisMan287 is offline
Old 01-07-2019, 02:36 PM
Egr valve delete
how do yo delete the egr valve?
Frank50e is offline
Old 01-07-2019, 07:11 PM
If you can keep it running with your foot goosing the gas, maybe check the IACV.
The system that keeps the idling smooth.
KP11520 is online now
Old 01-07-2019, 07:33 PM
Update
Seems to have been a one time deal.I wear a prothesetic leg and my stump is infected so I am dependent on my wifeís non mechanical feed back because itís many steps to the garage.Think Iíll have her buy a can of Seafoam and throw it in.Have had good success with that stuff on small engines tho I am usually not a big additive believer.
Frank50e is offline
Old 01-07-2019, 10:34 PM
JvG
​​​​​​Frank,now I understand why you have several issues with your car.
The others have mentioned the iacv. Yes, that unit probably needs to be cleaned and serviced.
There are passages in there which a measured amount of air passes through so that the car can idle. The passages become smaller over time as crud collects in them. Kinda like blocked arteries in a human. So lack of air flow will eventually lead to stalling.
JvG is offline
Old 01-07-2019, 11:29 PM
My best to you on all fronts! Get better soon!
Supreme Allah
18
05-20-2006 03:02 PM
NismoMaxman2
10-16-2004 07:51 AM
JetBlack SE
03-02-2004 10:07 PM
maxdick
03-10-2003 04:49 PM
Quick Reply: 95 Maxima starts then dies
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
