DS auto non-VLSD CV axle HELP Please
Old 01-06-2019, 07:57 PM
I have replaced the PS CV axle without much trouble. However I cannot seem to get the DS axle all the way into the transaxle - see picture.
I have so far avoided BANGING on any part of it...I suspect that the "press fit circular clip" noted on page FA-15 is not properly fit into the side gear. BUT I don't know how I'm actually supposed to resolve that.
I would really appreciate some advice. Not going to finish tonight unfortunately...
BrianA in Houston
reallywildstuff is offline
Old 01-06-2019, 08:49 PM
Try to remove the metal ring from the axle (just for the sake of the test), and see if it goes in smoothley.
I had the same thing with mine (APWI axle), and i had to hammer it in. All is well since.
bvb_09 is offline
Old 01-06-2019, 09:25 PM
Clock the passenger side wheel to try and move the second set of splines into place. Use the outer CV as a slide hammer.
95naSTA is offline
Old 01-07-2019, 06:34 AM
I'm nutty for Nissans
JSutter's Avatar
A little grease on the clip will help keep it centered and easier to install.
JSutter is offline
Old 01-07-2019, 07:21 AM
It's definitely not fun fighting that clip but with a little love it should go in.
I'd try the axle without it first to make sure there isn't another issue and then have at it!
ChrisMan287 is offline
Old 01-07-2019, 08:37 AM
"what kind of grease" ?
Old 01-07-2019, 10:37 AM
JvG
Anything slippery. Even bacon grease.
JvG is offline
Old 01-07-2019, 04:03 PM
Originally Posted by jvg View Post
anything slippery. Even bacon grease.
lol..
Once I get everything lined up, then I thread the old nut on the end of the shaft to protect the threads, then I hold it in position and give it a tap on the end with my 10lb sledge hammer.
CS_AR is offline
Old 01-08-2019, 07:30 AM
JSutter's Avatar
Whatever is on hand. Usually red n tacky or general purpose lithium for me.
JSutter is offline
Old 01-08-2019, 08:03 AM
On hand I have (all Sta-lube brand) Grease:
Lithium General Purpose (white)
Extreme Pressure Moly-Graph Multi-Purpose (unopened - I think it's black)
Hi-Temp Disc Brake (unopened - red?)
Which one of these will I adulterate my trans fluid with? I realize it's maybe trivial but it's a choice...
I haven't tried to insert the axle again since my last post...
Old 01-08-2019, 08:48 AM
Petroleum jelly?
Old 01-08-2019, 10:01 AM
Originally Posted by ChrisMan287 View Post
Petroleum jelly?
Indeed I have some Petroleum Jelly as well.
Old 01-09-2019, 08:51 AM
wxm
Try to turn the axle slightly. The spline needs to line up.
wxm is offline
Old 01-09-2019, 07:43 PM
Petroleum Jelly FTW!
I coated the circumference of the drive shaft inside/underneath the C-clip - this keeps the C-clip centered, which was previously mentioned by someone else.
After that the previous amount of force I was applying to insert the axle turned out to be enough.
Thanks for the Help / Moral Support
BrianA
95maxrider
01-21-2012 05:20 AM
NISSANMAXIMA91
11-21-2008 09:09 PM
KEhrhardt
04-29-2006 07:46 PM
Yourself
12-01-2004 11:32 PM
nismo2020
06-30-2004 07:16 PM
Quick Reply: DS auto non-VLSD CV axle HELP Please
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
