Go Back  Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Reload this Page >
computer swap - what needs to match and is repregramming needed?
Old 01-12-2019, 04:51 PM
I apologize since I know this has been discussed somewhat before but I am getting conflicting info reading about this and I need to know for sure before attempting to replace my computer. Specifically, five questions:
Does the computer I put in ...
1. need to be from a car of the same year (97) or just same generation?
2. need to be from a car of the same transmission type (manual)?
3. need to have the 2 digit code match my old computer exactly?
4 need to be re-programmed to match my key or security system? If so, can only the dealer do this or any locksmith or even a regular shop?
5 need to be specific to CA-spec cars? Mine is a CA car
plat is offline
Old 01-13-2019, 08:15 AM
Rit
What year is your Maxima ?
Rit is offline
Old 01-13-2019, 12:37 PM
The 95, 96 and 99 ECU are a lot different than yours, stay away from them and don't even try them. The 97 and 98 are pretty much the same. Transmission type and emissions type make a difference. If you get and ECU from a donor car equipped like yours, you don't need to get it reprogrammed, otherwise yes.
Locksmiths don't reprogram car computers. An independent repair shop might, but they are few and far between. Ask around. You probably will have to use a dealer.
It is rather rare that an ECU has to be replaced, so the question is - Why are you replacing the computer?
If there are burned up chips in the ECU, there are repair services that will fix them. Prices vary, bu you should be able to find one for $150, maybe less.
DennisMik is offline
Old 01-13-2019, 05:55 PM
Thank you so much for the info, it looks like the biggest challenge will be finding one from a manual.
I'm replacing the ecu and alternator in hopes of fixing whatever is causing the car to rapidly burn through ignition coils, 14 so far. I have scoped the trigger signal and someone on another forum said the waveform coming from the ecu looks terrible and that ecu malfunction is likely overheating and burning the coils. They get extremely hot and melt from the inside. I have eliminated spark plugs and every other possible cause.
Despite still charging fine, the alternator was tested to have an open diode so possibly dirty power has damaged the ecu or is having some effect here as well.
plat is offline
gxe2se
09-10-2004 11:27 PM
LeX
04-01-2004 02:18 AM
apeg
08-16-2003 11:44 PM
Quick Reply: computer swap - what needs to match and is repregramming needed?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
