Need to find part number on power steering pump
Old 02-13-2019, 11:19 AM
Hi all!
My 1995 maxima started leaking power steering fluid. The mechanic at a local garage instructed me to find the part he needs online as his supplier is back-ordered and couldn't get me anything for the next few months. I was told it is a small metal pipe, sllightly over 1 foot long, next to the rack and pinon. He stressed that it is NOT the return nor pressure pipes. Here is a picture of a similar kind of pipe (but it is not exactly the same).
I unfortunately cannot find the right part number on Nissan Usa parts website. Does anyone have some experience with the power steering on those models and could help me?
papomaster is offline
Old 02-13-2019, 11:54 AM
https://parts.nissanusa.com/nissanparts/index.cfm?action=replacement&groupid=I%20&sectioni d=497&partcode=49125&jointvehid=10036&siteid=14&pa rtnumber=491800M000
Your part will be in one of those diagrams. Search the lookup code from the diagram and it will give you the part number. You can put that part number into Google if you're looking for a cheaper price. If the part is discontinued everywhere get it at a junkyard
Violator is online now
Old 02-14-2019, 09:29 AM
with respect: what part of that hard line is leaking ?
reallywildstuff is offline
Old 02-14-2019, 01:25 PM
Its probably an o-ring or hose issue unless someone manually broke the hardline
Old 02-14-2019, 03:36 PM
IF the seals _inside_ the rack are leaking THEN rebuilding/replacing the rack is the only thing that's gonna fix that.
I have had this done - after I had replaced all the weeping 20 year old power steering hoses with new OEM (after which fluid under pressure had no where to go but OUT the leaking seals in the rack).
Old 02-14-2019, 04:50 PM
I'd assume you're for sure the line is actually broken but I would think you'd have a picture of the actual line. One of those hardlines wouldn't break by themselves, I'm picking up a replacement tomorrow for one I twisted to hell and broke. It uses an o-ring as well.
Furthermore if your hardline had broken then I would think it would be a massive leak and you'd be pouring/spraying fluid
Old 02-15-2019, 06:17 AM
Reminds me of an old house and plumbing issues..
CS_AR is offline
Old 02-25-2019, 11:11 AM
Actually, it is the metal piping that has developed some rust over the years, and the rust has broken up in parts, letting fluid go through.
Old 03-03-2019, 04:47 PM
anyone? On the nissan parts website it doesn't say which pipes are either made of metal or rubber.
HiQ
09-16-2013 06:45 PM
Mr. Brett
08-28-2009 06:54 PM
tomservo291
11-11-2007 08:51 PM
mdeal
02-26-2006 08:49 AM
Quick Reply: Need to find part number on power steering pump
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
