Which boots will work with Hitachi Ignition Coils
Hi, new member here, I have a 96 MAXIMA GXE and looking to get new ignition coils, boots, and plugs. I am not sure what boots to get. I am planning on getting the Hitachi coils part numbers: IGC0012 & IGC0015 from Rockauto due to them being a reasonable price but when looking at a few of the different boots that I am interested in getting from Rockauto they say either use w/ Hanshin coil or use w/ Mitsubishi coil.
For example: "NGK 58994 Info FitsRight Bank (Cyls. 1,3,5); Use w/Mitsubishi Coil OrLeft Bank (Cyls. 2,4,6); Use w/Mitsubishi Coil" I assume this means these particular boots are to be used only with mitsubishi coils. None of the boots on Rockauto say use with Hitachi coils so which boots will work with the Hitachi coils??? Am I missing something? Am I having a stupid moment? Is this not kind of weird... The Beck/Arnley boots do say multi-coil system; does that mean they will work with different types/brands of coils; specifically will they work with Hitachi coils? Anyone know? Thoughts? Would greatly appreciate a 2nd, 3rd, or 4th opinion here :D Thank you! https://maxima.org/forums/images/smilies/smile.gif I posted this in the newbie thread just now and then after posting I read that the 15 post rule is no long in effect for new members so am posting it here in the main thread as the post stated. Hope that is alright. Thank you. |
The boots should come with the coils. If not, you can detach the old boots and put them on a new coil. I have done this a couple of times.... as long as the boots are in good condition. I don't think the brand matters.
Thank you for the reply. :) I appreciate a 2nd opinion. Yeah I really don't think the brand of boot matters; as long as the boot and coil physically fit, connect to each other, don't see why or how they wouldn't work. Just found it interesting that some of the boots on rockauto say use with hanshin coil or use with mitsubishi coil or multi-coil system.
Going to clean my throttle body for first time (96 maxima 131xxx miles) and clean IACV too before I do the plugs/boots. Thanks again. |
The plugs and boots are easy. I keep spare coils in my trunk and install them on the fly, if a coil misfires while I am on the road. I am putting off doing your other two things until I have to do them. Right now my car is running like a champ, but I will need to do my cv axles soon.
Originally Posted by PH98I30
(Post 9195899)
CV axles soon eh, going to do them yourself? How many miles and what year is your maxima?? I had a guy do my axles then later looked into it and realized it isn't too big of a job; it doesn't look like it is anyways. Kicking myself over the money I could have saved. Cheers |
I would normally do them myself, but my co-workers husband is an ASE Toyota and Nissan mechanic. He said he would do them for me at his home/shop garage with a big discount. I might go and watch over a beer. I have an I30, which is the Infiniti version of the Maxi. I just turned 168K on the original cv axles.
Be sure to place some dielectric grease inside the boots so that the boot to spark plug engagement is sealed providing a hotter, more consistent spark and even if the spark plug tube fills up with oil it won't kill the cylinder...
Originally Posted by CMax03
(Post 9196775)
Btw PH98I30, the Hitachi coils I ordered from RockAuto came and yes they did come with boots! I was pleasantly surprised! The picture on their website showed the coils with boots on them but I was sure they wouldn't actually come with as it seems in general that everything pictured isn't always included lol. Glad I was wrong. Will keep the extra set of boots as not worth the shipping it would cost to return them. Got an extra pair of boots now. :) Waiting for dealer to get the throttle body and IACV gaskets I ordered then will clean the TB and IACV, probably clean the MAF sensor while I'm in there, then do the coils/boots/plugs, then check idle, run it 30-50 miles then an oil change. My Max actually idle's fine, is within spec 650-700 at idle but once in awhile she will idle rough and die at first start in the morning- seems to only happen in the colder weather but doesn't happen often at all. Not sure what I'm doing will help necessarily but it won't hurt I'm sure.
© 2024 MH Sub I, LLC dba Internet Brands
