What's possible to fix camber and toe?
I continue to invest regular maintenance in my Maxima: and today want to ask what is possible to fix camber and toe.
https://cimg9.ibsrv.net/gimg/maxima....18c0f29b92.jpg Alignment results from October 20 |
Let's pretend all of your control arms, bushings, bearings, springs, and struts are perfect.
The front has a tiny amount of play at the 2 bolts joining the knuckle to the strut. You can install camber bolts to get more adjustment. The rear has no adjustment. You would have to bend the beam or replace it. |
There is no camber adjustment possible in the 4th Gen ... just other worn parts that result in off-spec. camber.
https://cimg3.ibsrv.net/gimg/maxima....9611ffee4.jpeg |
(Post 9230230)
https://cimg3.ibsrv.net/gimg/maxima....9611ffee4.jpeg https://www.rockauto.com/en/catalog/...bolt+kit,13512 Also you can get caster bushings and even camber plates to adjust even further. |
^^^ that’s right out of the FSM.
Thanks @Turbobink and @JSutter : I agree that factory does not allow adjustment. I have the factory manual (I paid for mine back in the day, but I think people can find it all online for free).
I checked out a video about changing this bolt to see what's involved. I think my path will be work with my regular mechanic to see if he will do it. It looks like I would need four of them, two for each side. I've been a Rock Auto customer, but I'm leaning toward still having the mechanic do it. My alignment package is life, so I can just go back for that to be done again. Now on the back side -- I agree about little can be done there. But I'm thinking about having those old (certainly over 15 years old) struts evaluated, and maybe that would help it all work better. |
(Post 9230245)
Originally Posted by marktab
(Post 9230263)
| All times are GMT -7. The time now is 06:16 PM. |
