so that they will b brite as if i was signaling
I'm assuming your talking about a 95-96 Maxima, as they have dual filament bulbs in the corner lights. You can take the bulb out then sand off one of the posts on the side. Push the bulb back into the socket turned 180 degrees. Tada...
If you blow the fuses..>
there are two under the drives side panel and in the engine compartment on the drivers side is one more.
I tried and blew-out some fuses. When the fuses are out so are your taillights. :( That is if you try this cool Wiseguy short cut, you might need the above information. :P |
It's dual filament on all 4th gens.
EricGP has a 97, and we did his. The wiring harness is actually a dual filament, they just don't have a wire soldered into the brighter filament conncection. Since you are re-wireing your conrers, why not do your turns also? On my car, my corners are bright all the time, plus my turns stay on constant, so they match my side markers, and they blink brighter. If you want to do the turns also, give me an email and I'll send you info.
I agree with slickmax too. His way is more permanent and professional. Both ways are will work just fine.
Regards Wizeguy |
© 2024 MH Sub I, LLC dba Internet Brands
