Will 18's fit?
Old Feb 27, 2002 | 01:40 PM
SoCalMax96's Avatar
Will 18's fit?
I am planning on buying some used 18s. The tire specs are 225/45/18. Will these fit on a 96 SE without rubbing? I also plan on getting H&R springs and Tokicos to compliment the setup.
Old Feb 27, 2002 | 01:44 PM
mark w chrzanow's Avatar
I am running 17s up front and 18s in the rear
with the eibach springs and kyb agx combo and they
work good.
Old Feb 27, 2002 | 02:01 PM
SuDZ's Avatar
Re: Will 18's fit?
You will be fine.
SuDZ
Old Feb 27, 2002 | 02:06 PM
GaMax97GLE's Avatar
yes
I am running with 18x7.5" wheels, 235/40/18 tires, dropped with H&R
Old Feb 27, 2002 | 02:27 PM
pawn's Avatar
Re: Will 18's fit?
wrong size tire...45series is used on 17's...
Old Feb 27, 2002 | 02:30 PM
sureal00's Avatar
work good.
do u have a pick of your car with 17's in front and 18's in the back
Old Feb 27, 2002 | 02:54 PM
SuDZ's Avatar
Re: Re: Will 18's fit?
Depends on if they want more rubber for more rubber in some areas. Like some people with bad roads like the 45's.
SuDZ
Old Feb 27, 2002 | 02:59 PM
I will this weekend
Old Feb 27, 2002 | 04:04 PM
OgreDave's Avatar
itll fit no rubbing, depending on offset. the rubber and everything else is fine, but be careful to get +38 - +42 or so, for a good fit.
if you do like kevwong and get +50's, youll need spacers, and maybe longer studs.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
