Engine coolant drain plugs
Ok, this question is more about draining procedures because the searches I've done turned up posts I read that indicate what I already learned, the engine drain plugs are impossible to get at, I swear I'd have to take off the exhaust manifold. So... How can I check the coolant/water ratio without draining all the coolant? Here is what I did. flushed the system until it ran clear and then filled and drained one last time, i got about 5 quarts out, I then filled with 100% antifreeze giving me a 50+ of coolant and 50- of water but certainly not more than 70/30, I also filled the overflow with pure antifreeze. Does this match what others are doing?
Re: Engine coolant drain plugs
Why not just pre-mix the anti-freeze and water at 50%, then pour it in?? That's what I did. That way you know you will be not more than a few % off of 50/50 for the whole fill.
DW Originally posted by sarmast Ok, this question is more about draining procedures because the searches I've done turned up posts I read that indicate what I already learned, the engine drain plugs are impossible to get at, I swear I'd have to take off the exhaust manifold. So... How can I check the coolant/water ratio without draining all the coolant? Here is what I did. flushed the system until it ran clear and then filled and drained one last time, i got about 5 quarts out, I then filled with 100% antifreeze giving me a 50+ of coolant and 50- of water but certainly not more than 70/30, I also filled the overflow with pure antifreeze. Does this match what others are doing? |
Auto parts store sell these gauge that you suck some mixture up into it. It will measure what your mixture is.
Re: Re: Engine coolant drain plugs
Originally posted by dwapenyi Why not just pre-mix the anti-freeze and water at 50%, then pour it in?? That's what I did. That way you know you will be not more than a few % off of 50/50 for the whole fill. |
Originally posted by 1MAX2NV Auto parts store sell these gauge that you suck some mixture up into it. It will measure what your mixture is. |
Originally posted by sarmast Oooh! Whats this dealy thingamabob all about? You can by a tool that sucks the solution in (like a turkey baster) and will show you on a scale how your coolant is...tried to find it at PepBoys.com, but, like most auto tools sites, it really sucks... best, Flo_Boy |
I have no idea how it works...maybe it has something to do with density of the fluid mixture. Anyway it's a $10 tool that you buy at any auto part store.
Originally posted by sarmast Oooh! Whats this dealy thingamabob all about? |
Originally posted by 1MAX2NV I have no idea how it works...maybe it has something to do with density of the fluid mixture. Anyway it's a $10 tool that you buy at any auto part store. |
I believe it's called a hydrometer and it measures the specific gravity of a solution. Liquids denser than water will have a higher specific gravity, while liquids less dense will have a lower specific gravity.
© 2024 MH Sub I, LLC dba Internet Brands
