Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   rear agx's only (https://maxima.org/forums/4th-generation-maxima-1995-1999/83183-rear-agxs-only.html)
NotNew!!NewSN!! Apr 17, 2002 08:14 PM
rear agx's only
after progress spring install, its much more prominent on how the rear shocks are too soft with 67k on them, i cant afford both, and the fact that its so easy to take the rear suspension apart, i figured id install rear agx's for a couple months, then id be able to afford the fronts and put them on. by doing this, would i mess up the front shocks at all even with keeping the rears on a fairly softer setting? the ride is definlty bearable, only every now and then its a lil bouncy in the rear and a lil wild, but thats only on straight aways, it still corners perfectly, anyone? thanks i know everything at once is always best choice, but not everyone can afford everything at once, but can afford over a period of time(like how i financed my car:D )
Chunger Apr 17, 2002 11:55 PM
Re: rear agx's only
Doing the rears should be fine... the SE shocks (if not dead) are firmer than the non-SE ones. Get the fronts afterwards though.
