Oil Change Question
Oil Change Question
I'm fairly new here, but have a question I haven't seen come up, and yes I have done the "search" thing. Basically, what's happening is this. I just recently acquired a 99 Infiniti I30t, right after the oil changes have been completed I have noticed the oil has stayed dark. Yes, I'm getting it done by a quick lube place, but watch to make sure they are doing it right, this hasn't happened to my other vehicles which I have also taken there, so I'm a little confused why it's happening with this one. Is it possible not all the old oil is coming out during the change? What should I look for?
Brent
Brent
Re: Oil Change Question
Brent
Brent
Re: Re: Oil Change Question
Originally posted by ljl10
Are you saying that your oil is the same dark, dirty color before and after the oil change? Do you have the previous owner's maintainance records of the car? If you're bringing the car in there warm, then I don't see any reason why the oil would not drain completely. They DID change the filter, right?
Brent
A few things come to mind. First, try having them use a different brand of oil and see if the color is the same, some oils are just darker than others period. The other possibility is that you may have a filtration problem, it could be an air filter issue which is letting an excessive amount of dirt into your system. It could also be an oil filter issue as well. If the pasageway to/from the oil filter is restricted in anyway and the filter is being bypassed the "clean" oil being put into your engine can be circulating unfiltered or partially filtered, leading to an extremely short service life and a contamination problem.
Originally posted by thrustinj
No not all the oil comes out of the engine when you change oil. The oil pan keeps some of the old oil, along with any crude that built up.
I may be wrong here.
I've read that some of the "quick oil change" places do it like this:
1. Change filter
2. Use a type of syringe to suck out as much oil as they can (or want) from the oil pan.
3. Pour in new oil
This method would leave in even more used oil that would be just in the filter. I don't know...just something I've read. That's why I don't mess with fate and do it myself. If that's not an option, the Nissan/Infinity dealership is only going to charge $20-$25, and I'd assume that they would do it right.
1. Change filter
3. Pour in new oil
1. Change filter
3. Pour in new oil
1. Change filter
3. Pour in new oil
SuDZ
Brent
Brent
Just drop in the flush before you drain your oil. Start your car and get it up to normal operating temp. Remember if you car is cold and you change the oil, its thick and drains out slow (not good). The warmer the better, always be carful you can get burnt.
On a broken in engine, it is not unusual for oil to get dark really quick. As long as you are changing the filter each time, it should not be something to worry about in my opinion. If you are really worried, then do a Blackstone oil analysis on your used oil (like when you change it) and then take another sample 500 miles later when the "new" oil is dark. Blackstone should be able to predict if you are experiencing unusual wear in the engine.
danger of using oil flush
1eyedcalibandit Quoted Message:
I do an oil change just about every three weeks regardless whether or not my car needs it. Each time before I do my oil change I drop in a can of oil flush (can be found at any automotive store). The oil flush helps breakdown the dirt and thins the oil out.
MAYBE the above works if it is done starting when the engine is new. Years ago, I know I tried it on a car I bought used and all it did for me was make the engine use lots of oil. I have never used oil flush since.
Originally posted by Str8ridin
Anybody consider that the 'quick lube' place isn't really changing the oil or perhaps adding used motor oil in to save money? Try going to a different place.
Brent
Re: danger of using oil flush
Ps the car you bought was years ago, has nothing to do with my Maxima, im just stating that I havent had one single problem with burning oil because of oil flushes.
I have spoken with the dealer and automotive store part guys, some have negative comments, others have positive, use at your own risk!
Uhh, one problem with this, I watched them change it each time. Anyway, today it was taken care of. I decided to do another oil change myself, the only reason I was having the quick lube do it was for warranty purposes, which I have since been told is unnecessary, so from now on I will do it myself. After letting all the old oil drain out, I decide to run a couple of quarts through just to see what happens, and the oil continues to run black for the first 1 and a half quarts then it becomes clear. I then refill the oil, and check it, now I can't see it because it's so damn clear, but that's what I wanted. It's a good possibility the car wasn't serviced correctly by the po, are there any other problems I should look for? Considering the po didn't care
Brent
Brent
? how many quarts are you using, do you have an oil cooler on the car?
Originally posted by 1eyedcalibandit
Just keep an eye on the color and remember to smell your oil cap each time you change it. Do oil changes every 3k and you should be fine,
Brent
MatthewsMaxima
09-11-2015 03:21 AM
maxinout93
08-20-2015 02:17 AM
