How high of a profile can I go on 18" rim not lowered max?
I would like to reduce the "appearance" of the gap I am gonna have with 18's. I DO NOT WANT TO LOWER IT right now. So how high can the profile go to fill that massive wheelwell?
Re: How high of a profile can I go on 18" rim not lowered max?
To answer your question theres no possible way you will close that gap on your car, by installing 18's guess what will happen? your gap will increase and it will lift the car off the ground even higher. I have cut front springs and I did not fill up that space. The biggest safest is 245/40, all around. Or you can do the uncle max since I saw his car this weekend, 18x10 with 265/35 18 in the rear only. Your best bet will be 245/40 18. 18x8 wheel
Re: Re: How high of a profile can I go on 18" rim not lowered max?
Originally posted by JAY25 To answer your question theres no possible way you will close that gap on your car, by installing 18's guess what will happen? your gap will increase and it will lift the car off the ground even higher. I have cut front springs and I did not fill up that space. The biggest safest is 245/40, all around. Or you can do the uncle max since I saw his car this weekend, 18x10 with 265/35 18 in the rear only. Your best bet will be 245/40 18. 18x8 wheel |
Will a 17" wheel with 215/55 tires fit on a max without rubbing?
Originally posted by gedck Will a 17" wheel with 215/55 tires fit on a max without rubbing? NO!!!!and whats with the 215/55 size???, thats not even the right size to go with when you go 17 do it right the first time and get 17x8 235/45 17 tire and you will be good!! you need unclemax about rubbin issues thats what I saw on his car |
© 2024 MH Sub I, LLC dba Internet Brands
