Max's with H&R do you have spring noise?
I'm curious to know how many of you guys with H&R's have spring noise and how many of you guys are nice and quiet.
I had H&R's last summer, took them out because I could not stop the spring noise. :mad: Summer is here again and I'm thinking I might put another set of springs in my car, but if I wind up with the noise again I'm going to go nuts. Only my fronts made noise, the rear was nice and quiet. I know all the tircks to make them quiet, I wrote most of that sticky thread. I could get them quiet, only for the noise to return 2 weeks later. Now I'm thinking it may have been the way they were installed. Perhaps upside down? :gotme: Maybe H&R's are prone to noise and others such as MaxSpeed or B&G's aren't. I do like the drop the H&R's provide the best and they did ride pretty damn good too. Couple them with the AGX's I'm running right now and I think the ride and handling would be totally awsome. Any input would be appreciated. Thanks guys. This sig pic was taken last year with the H&R's in my baby. I love the drop, it made the car look like it should have from the factory. |
Re: Max's with H&R do you have spring noise?
Hey man,
I need a ride in your car I want to switch my Eibach Tokico for H&R/Tokcio or H&R /AGX. I think that would help me make my decision. Where in NJ are you? Kevin |
No noise*knock on wood*, have H&R/Tokico set up since May of last year
Re: Re: Max's with H&R do you have spring noise?
Originally posted by Kevin Hey man, I need a ride in your car I want to switch my Eibach Tokico for H&R/Tokcio or H&R /AGX. I think that would help me make my decision. Where in NJ are you? Kevin |
My H&Rs are silent...
my H&R's have never made any noise
Re: Re: Re: Max's with H&R do you have spring noise?
Originally posted by njmaxseltd Kevin I'm in Bergen County, just north of Paramus. KEvin |
I've had AGX/H&Rs for a little over a month, and they are very quiet.
My H&Rs were silent. It's been about 8 months and now my front left strut is annoying now:mad:
I tried to do that wire wrap thing that Lime wroteup about, but I can't find that stuff at Radio shack or Home Depot. I luckily found one wire wrap that I used on my rear wheel. The H&R noise is bumming me:( Anyone got any 19mm wire wrap they can send to me? DW |
I heard that you definitely need wire wrap on those H&Rs to kill the noise. Apparently a number of people went through the same pain, put in the wire wraps, and are extremely happy with the results. Search the forum for postings...
Just to let you know, my H&R's make noises ever so slightly but noticeable.
Right rear "clunks" when negotiating uneven stuff like driveways.:goofy:
Originally posted by dwapenyi My H&Rs were silent. It's been about 8 months and now my front left strut is annoying now:mad: I tried to do that wire wrap thing that Lime wroteup about, but I can't find that stuff at Radio shack or Home Depot. I luckily found one wire wrap that I used on my rear wheel. The H&R noise is bumming me:( Anyone got any 19mm wire wrap they can send to me? DW |
H&R/KONI.
Have left rear creaking noises when I get in the car and just driving on flat pavement. Not sure but I think it's coming from either the coils rubbing or the bottom coil on the spring mount on the Koni shock (metal-metal interface). I still haven't ruled out my addco RSB though! |
H&R/AGX combo...
When I drive straight or while turning, there are no noises. Even when I turn the steering wheel all the way to the right or left...no noise. When I go over mild bumps while driving straight or turning...no noise.
When I go up a driveway at an angle, I hear a slight 'erk' noise from the front driver's side spring. When I go over a speed bump fairly fast, I hear a squeak from the rear.:mad: I just got an alignment done a couple of weeks ago, and it seemed to quiet down my suspension a bit. Overall, I think my setup is 'quiet'...with a couple of quirks that is....oh well. Anyway...my 2c. |
H&R/Tokico No Noise. :D
Had it for nearly a year now. |
KYB/H&R's & no noises
Yeeah, I've been to 4 home depots in my area in the electrical section. No luck. They all had that smaller wire wrap.
DW Originally posted by spiff56747 it's in the electrical section of home depot. where all the phone and video cables are.. you should be able to find it there. i bought mine in a combo pack, a thick wire wrap and thin one (thin one is useless). they are like 99 cents each or something like that. |
I dont have H&R's but I dont see why you guys are having so much problem with your springs making noise. I usually hvae bad luck with this car and I have Sprints and AGX, and the only part I replaced were the dust boots. EVERYTHING including the polyurethane coil insulaters that were stock and a little worn were reused. Yet I have had ZERO problems with noise from the suspension.
My 1990 Camry lowered by Intrax and KYB GR2, with completely reused parts down to the splitting dust boots and deteriorated bump stops and insulators and it too never had any noises. What is going on here? |
Rear creaking gone!
Had the day off and weather was good so decided I would re-do the rear suspension, looking for anything that might be the cause of this creaking noise, mainly from the driver's side rear.
First, went back to my stock springs and noted their condition. To my surprise, they still had the lower spring insulators on them! DOH! They were almost the exact same color as the springs so I just assumed they didn't come with them (like the fronts did). I was almost happy about this though as I was hoping this was the answer I was looking for. When I took down the spring/shock assembly, I noted a lot of contact wear on the upper coils of the springs (the ones that are packed pretty tight) where the coils come in contact with each other (just as others have reported). I used the Radioshack wire wrap in segments to cover the 2nd through the 4th coils from the top. While I was there, decided to stiffen up my KONI's by 3/4 rotation too(they were previously on the softest setting). Anyways, to my complete and utter joy, the car no longer creaks in back! It no longer sounds like a POS! Leave it to me to mess up the install in the first place although I can't rule out the wire wrap either. Woooo hooo! Anyways, while both spring/shock assemblies were off, I jostled the rear axle and no noise was heard from my Addco RSB, so I ruled that out as a possible cause (I was thinking about relubing it). |
| All times are GMT -7. The time now is 02:43 AM. |
