Why do bigger rims yield a harsher ride?
I can understand chanign your suspension. But what is it about bigger rims that give you a harsher ride? is it the width?
Re: Why do bigger rims yield a harsher ride?
the lack of cushion from less air volume in the smaller tires.
Re: Re: Why do bigger rims yield a harsher ride?
Originally posted by saggleman the lack of cushion from less air volume in the smaller tires. Not only less air but less side wall means less rubber = Harder ride. |
Re: Re: Re: Why do bigger rims yield a harsher ride?
Originally posted by njmaxseltd WOW - 1st post was a good one! Informative and straight to the point! Not only less air but less side wall means less rubber = Harder ride. |
Re: Re: Re: Re: Why do bigger rims yield a harsher ride?
Originally posted by maxwillden Less sidewall = STIFFER sidewall = Stiffer Ride... |
Originally posted by saggleman the lack of cushion from less air volume in the smaller tires. |
i can ride on tires with no air with 20s. for like a week i didnt have any air in one of my tires and i didnt know until i was checking the pressure... and the ride difference isnt as dramatic as people act..
Thanks all. Pretty much makes sense now. wonder why I couldn't think of it myself.....looks like its time to cut back on the yuengling's :D
woa those are some nasty chrome rims u got there!
Re: Re: Re: Re: Re: Why do bigger rims yield a harsher ride?
Originally posted by FJC Chicks dig less sidewall :cool: |
i believe, if I remeber correctly, in order to maintain the "similar" ride you would have to increase the width of the tire as much as the rim size....for example, if you get 19's, (lets say 3 inches over stock) then you would have to increase the width by 3 inches to compensate. however in many cases this is unrealistic, and you would rub against the wheel well. so you might end up only getting 1-1.5 inches wider if your lucky. this is all conjecture so dont quote me on this.
© 2024 MH Sub I, LLC dba Internet Brands
