Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Can't find the coolant temp sensor (https://maxima.org/forums/4th-generation-maxima-1995-1999/98996-cant-find-coolant-temp-sensor.html)
mohfo Jul 5, 2002 08:42 PM
Can't find it
I can't find the coolant temp sensor, yes i did a search. Please help.
1MAX2NV Jul 6, 2002 11:05 AM
Find the upper radiator hose. Follw it towards the engine. You will see two brass sensors with wires attach to them. The sensors are screwed into this aluminum water neck. Those are the coolant temp sensors. One is for the gauge and the other one is for the ECU.
mzmtg Jul 6, 2002 11:08 AM
The ECU gets to know that actual coolant temp. When we read the gauge, we get three options:
cold - needle down
warm - needle in the middle
hot - needle up
:rolleyes:
njmaxseltd Jul 6, 2002 11:12 AM
From the hose - The first sensor is for the temp gauge, the second sensor is for the ECU.
Ginuwin3112 Jul 6, 2002 12:23 PM
How can u tell if the one for the ecu has gone bad?
I replaced my gauge sensor and it still doesnt work:(
