FS: 3mm Spacers for 00 to 03 maxima's.
Used for few days. these may fit all maximas as long as there are 5 bolts. you dont need any longer studs as long as you staying between 3 to 5mm splacers. these will bring your wheels out a little bit.
$26.00 shipped Location: OC, CA http://img.photobucket.com/albums/v6...1/DSC04516.jpg |
Wouldn't these fit all Maximas? Also need for longer studs or no?
if they can fit my 02 i think they will fit all maxima's as long as there are 5 bolts. You dont need longer studs..you can put 3 to 5mm spacers on your car with stock studs on it. i got 5mm in the back without going with longer studs and they fit just fine. To fit 5mm in the front you may need longer lug nuts but not longer studs. The only time you need long studs when you putting 10 to 25mm spacers.
You shouldnt need longer studs I put a set from my buddies mustang on the back like these. He said they were seven sixteenths. Made my rears sit flush or more even with the front wheels.
i think you can go with 8mm without needing the longer studs and those are just 3mm
Just a couple of questions,
Are these aluminium? They look like steel or cast iron. Can you feel any shimmy with them installed? They don't look very balanced. |
i am not sure what material they are made of but they are pretty solid i got 5mm in the back and they are the same quality that i am selling. theres no shims installed with them or anything. If they dont get sold i will just put them in the back with 5mm.
OC, I'll take em off your hands. Do you take pay pal?
Payment sent.
oh ok i got it i just pm'ed you to make sure that you sent that payment. thanks i will ship them tommorow.
| All times are GMT -7. The time now is 12:54 AM. |
