LED's for Guages?
Does anyone know how many led's ill need to change the lights of the guages?
Thanks, Igor |
Re: LED's for Guages?
Originally posted by Igor911 Does anyone know how many led's ill need to change the lights of the guages? Thanks, Igor i think its 6 194 bulbs but i may be mistaken, some one please correct me if im wrong cause ive been meanin to change out the guage lights also |
assuming you have the gxe guages, the bulbs are soldered into the circuit board. theyre really small and dont look replaceable. i should know, ive tried. :(
Originally posted by MaximaZero assuming you have the gxe guages, the bulbs are soldered into the circuit board. theyre really small and dont look replaceable. i should know, ive tried. :( |
is their anyway to CHANGE THE LEDS on a GXE????? :bawling:
what about on a 2k2 SE?
the only bulbs u would be able to change would probably be the bulbs for the tach, speedo, fuel and temp.
Originally posted by Dario the only bulbs u would be able to change would probably be the bulbs for the tach, speedo, fuel and temp. |
guage bulbs...
so since the GXE and GLE guages are the same...im assuming the bulbs are the same...small and soldered to the circuit board? all im interested in changing is the speedo, tach, fuel, and the other guage cluster bulbs, to like i dunno...blue maybe...i dont know...i would have to try it to see what i liked...but can it be done?
Re: guage bulbs...
Originally posted by 2k1maxgle so since the GXE and GLE guages are the same...im assuming the bulbs are the same...small and soldered to the circuit board? all im interested in changing is the speedo, tach, fuel, and the other guage cluster bulbs, to like i dunno...blue maybe...i dont know...i would have to try it to see what i liked...but can it be done? |
Re: Re: guage bulbs...
Originally posted by Igor911 All i want to change are the lights for the speedometer, RPM guage, gas guage and the temp guage. IS THIS POSSIBLE ON A GXE AND WHAT KINDOF BULBS DO I NEED? OK HERE GOES: As per my research on this subject i have found the following the bulbs used in the 5th gen clusters<SE> are smaller than 194 i am not quite sure of the size but i think its 168 i have found 1 place that has LEDs this size and i am in the process of ordering them now. please refer to the pics below fo more info: please be aware that this is for a 2000 SE cluster others may be different http://images.cardomain.com/installs...37_34_full.jpg THE BULB ON THE RIGHT IS A 194-- THE BULB ON THE LEFT IS THE ONE IN OUR CLUSTERS http://images.cardomain.com/installs...37_35_full.jpg http://images.cardomain.com/installs...37_36_full.jpg if anyone has any further input on these bulbs please clear this up for me!! |
Re: Re: Re: guage bulbs...
Originally posted by Mr.max420 OK HERE GOES: As per my research on this subject i have found the following the bulbs used in the 5th gen clusters<SE> are smaller than 194 i am not quite sure of the size but i think its 168 i have found 1 place that has LEDs this size and i am in the process of ordering them now. please refer to the pics below fo more info: please be aware that this is for a 2000 SE cluster others may be different http://images.cardomain.com/installs...37_34_full.jpg[/IMG] THE BULB ON THE RIGHT IS A 194-- THE BULB ON THE LEFT IS THE ONE IN OUR CLUSTERS http://images.cardomain.com/installs...37_35_full.jpg[/IMG] http://images.cardomain.com/installs...37_36_full.jpg[/IMG] if anyone has any further input on these bulbs please clear this up for me!! I was actually thinking of sticking blue LEDs in the sockets in place of the small bulbs, but then you might run into voltage problems (and resistors will not fit in there). Another solution (ghetto) is if you notice, not all of the bulbs are the same brightness. There's brown light sockets (like you pulled out) and there are black ones, i believe. One of them are for your tach, etc, and the other is for your warning displays. The warning displays are the brighter bulbs. Thus, you can swap them with each other. Easy mod, just need a little bit of your time to gouge the cluster out. hope this helps. let me know if there are any other ideas. |
i have the SE gauges installed and they looked very similiar to the GXE gauge lights(i have a GXE)
Originally posted by Dario i have the SE gauges installed and they looked very similiar to the GXE gauge lights(i have a GXE) |
i bought them from ebay for 177.00. the only thing is that when u swap out the gauges u also have to swap out the circuit boards because the circuit board holds the mileage of the car.
Originally posted by Dario i bought them from ebay for 177.00. the only thing is that when u swap out the gauges u also have to swap out the circuit boards because the circuit board holds the mileage of the car. |
just keep checking ebay, a couple have been on sale once in a while. Thats what i did :)
Originally posted by Mr.max420 http://images.cardomain.com/installs...37_36_full.jpg if anyone has any further input on these bulbs please clear this up for me!! |
that W5W seems to be what was imprinted on the top of the bulb but have never been to sure about that until now, thanks
| All times are GMT -7. The time now is 04:42 PM. |
