Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   Knock, Knock...it's my Frankencar Intake! (https://maxima.org/forums/5th-generation-maxima-2000-2003/106891-knock-knock-its-my-frankencar-intake.html)
P-Daddy Aug 15, 2002 12:48 PM
Hi all,
I have a 2002 SE. Installed the Frankencar intake in May and life was good.
The bad news...
About a month ago the Max starts knocking when going up hills with the AC on. It got worse. A few days ago it would knock really loudly when I pulled out in 1st.
I was planning to take it to the dealer for a look-over, so I put the stock intake back on. After two days of driving I haven't heard a single knock. What's more, the Max seems to run better.
Any comments or advise?
(yes, the Frankencar was still installed properly/tightly and everything was clean)
buzek Aug 15, 2002 01:08 PM
Re: Knock, Knock...it's my Frankencar Intake!
Originally posted by P-Daddy
Hi all,
The bad news...
I noticed that if not positioned or bent properly the bracket will hit the brake line where it runs along the strut tower. It makes a sound like CV joints going bad, clunk knock knock
I used one of the rubber washers with the sleve insert from the OEM box mount to provide space.
2K2_6spd Aug 15, 2002 03:35 PM
I think he's talking about spark knock, and I had it too with my Hot air intake on, I put my stocker back on, and no more pinging.
Titleistprov21 Aug 15, 2002 03:58 PM
I have the same Pinging noise, but only going up hills.
2001SE Aug 15, 2002 06:29 PM
probably when the engine needs to work harder and needs more air and the air is really hot so there is pinging noise
buzek Aug 16, 2002 05:52 AM
Just open the hood and check..You might be find out different.
P-Daddy Aug 16, 2002 12:46 PM
buzek. Thanks, but I checked that. Everything was tight. It was definitely an engine noise.
Interesting to hear that other people are hearing pinging noises.
Frankencar is getting a call...
voltman Aug 16, 2002 12:49 PM
A10s are better. :D
