How do I tell if my 2kse is fed or cali spec?
Thanks. I'd hate to order the wrong stuff. :)
Re: How do I tell if my 2kse is fed or cali spec?
Originally posted by jjames Thanks. I'd hate to order the wrong stuff. :) http://www.custommaxima.com/images/YpipeImage.jpg cali spec has 4 sensors, fed spec only has 2. |
Re: Re: How do I tell if my 2kse is fed or cali spec?
Thanks man.
Originally posted by Axel Check picture: http://www.custommaxima.com/images/YpipeImage.jpg cali spec has 4 sensors, fed spec only has 2. |
OK
If you have 4 sensors, what does this mean for your HP? I seem to have a cali spec in Ohio? Can you still get a Y?
Re: OK
Originally posted by Colonel If you have 4 sensors, what does this mean for your HP? I seem to have a cali spec in Ohio? Can you still get a Y? |
Re: OK
Originally posted by Colonel If you have 4 sensors, what does this mean for your HP? I seem to have a cali spec in Ohio? Can you still get a Y? http://www.custommaxima.com/Ypipe.htm for the different y-pipes including a 99-01 cali spec y-pipe from custommaxima. I'm sure the other y-pipe manufacturers have taken this difference into account. Custommaxima sells the cattman one. |
Re: Re: OK
Originally posted by jjs If I am not mistaken, 2000's had Fed and Cali...after that ALL Max's were 'CALI' spec. I have been hearing good things about the Budget...anybody know why it was not a "premimum" option? If its 304 and mandrel bent..why is it not? Peeps seem to keep waiting for Warpspeeds? And Stillen is just $$$ I dont have. |
Stillen's Y pipes for Cali and Fed are identical. The only difference is that with Cali spec you won't be able to use the small downpipe piece.
Jjames...You putting in dual exhaust? I'd like to see it when your done dude...I want it on mine too :D
© 2024 MH Sub I, LLC dba Internet Brands
