Will a performance fuel pump stop my car's hesitation?
I have a 2000 SC MAX 5-speed with an upgraded 3.33" pulley and my hesitation problems are becoming more persistant. Will changing my fuel pump into a walbro High press. 255 l/h help out any? I know that our cars have hesitation problems but I am getting them more often. And yes, I already did a search but my question wasn't answered. IF anyone has any info on this, can u LMK. Thanx!
do u have Loren's mod on hobb switch? SC kit comes with a fuel pump already to support the stock pump.
If u dont have Loren's mod....give it a try, I heard it helps. the previous owner of my SC kit has this mod already..... so what's the hesitation like? just wondering. |
Originally posted by [maxi-overdose] do u have Loren's mod on hobb switch? SC kit comes with a fuel pump already to support the stock pump. If u dont have Loren's mod....give it a try, I heard it helps. the previous owner of my SC kit has this mod already..... so what's the hesitation like? just wondering. Dixit |
Originally posted by BigDogJonx What is this Loren;s mod on the hobb switch? If you put a Walbro 255lph fuel pump, you techincally dont need the hobb switch or any of that except the Vortech Fuel Pressure Regulator Dixit http://forums.maxima.org/showthread....ighlight=loren check out Loren00Miata and STeveChicagoSC's post it is to hardwire ur hobb switch on the Bosch pump that comes with the kit and to have it on all time. therefore, when u let off the gas pedal, it does not create any back pressure in the fuel line. |
Good info, but what about my question about if I just run the Walbro 255lph, I dont need to run the aux pump anymore correct? That means no need for the hobb switch.
Or is my thinking and what people have told me completely untrue, only reason I ask is because my Supercharger goes back on in 2weeks and I bought a Walbro 255lph pump just to get around the whole aux fuel pump wiring and install. Dixit |
Originally posted by BigDogJonx Good info, but what about my question about if I just run the Walbro 255lph, I dont need to run the aux pump anymore correct? That means no need for the hobb switch. Or is my thinking and what people have told me completely untrue, only reason I ask is because my Supercharger goes back on in 2weeks and I bought a Walbro 255lph pump just to get around the whole aux fuel pump wiring and install. Dixit oh....in that case, u already replace ur stock pump with a performance fuel pump....u dont even need the one from stillen, just the FMU. cutting the line and installing the adapters are not fun from teh aux pump....my fingers were sore for 2 days. btw, what pulley size are u using? and good luck on the install :) btw(1) - did ur insurance company pay for all the electronic items that were stolen from ur car? |
Originally posted by [maxi-overdose] oh....in that case, u already replace ur stock pump with a performance fuel pump....u dont even need the one from stillen, just the FMU. cutting the line and installing the adapters are not fun from teh aux pump....my fingers were sore for 2 days. btw, what pulley size are u using? and good luck on the install :) btw(1) - did ur insurance company pay for all the electronic items that were stolen from ur car? Unfortunately im going to post anything about my audio anymore, if you want to email i will tell you, hope you understand. Dixit |
Originally posted by BigDogJonx I am going to run a 3.125" pulley and going to install it in 2weeks when the car comes back from the audio shop where some work is going to be performed. Unfortunately im going to post anything about my audio anymore, if you want to email i will tell you, hope you understand. Dixit but the power still there.....hehehe and, I understand why u doing this...... |
So, what type of fuel upgrades is needed with a 3.125 pulley. I plan on getting a walbro 255 l/h high pressure fuel pump for fuel upgrades but is there anything else that i should install so I won't be running lean? If u have any info , let me know. Thanx!
~AC |
Originally posted by maxxboost00 So, what type of fuel upgrades is needed with a 3.125 pulley. I plan on getting a walbro 255 l/h high pressure fuel pump for fuel upgrades but is there anything else that i should install so I won't be running lean? If u have any info , let me know. Thanx! ~AC Dixit |
isn't the fuel pressure regulator the same auxillary fuel pump?? I'm confused :confused: . Or do I have to purchase a different FPR? I need some explanation of what is what. let me know. Thanx!
~AC ps. where did u get your fuel pump from? Did it come with an installation kit or did u just purchase the pump by itself? |
Originally posted by maxxboost00 isn't the fuel pressure regulator the same auxillary fuel pump?? I'm confused :confused: . Or do I have to purchase a different FPR? I need some explanation of what is what. let me know. Thanx! ~AC ps. where did u get your fuel pump from? Did it come with an installation kit or did u just purchase the pump by itself? I got mine off a dude on ebay. It was brand new. Dont really need an install kit, look in the FAQ of this forum (5th gen) and you can find a howto by STIKYA on how to put this walbro into the tank and remove the stock one. Dixit |
thanx Dixit. So, I'm guessing that the fuel lines have to go back to its stock setup, right? And The two hoses that are connected to the FPR should be left alone, correct? What about the electrical wiring? Do I leave the wires connected to the Aux. fuel pump or do I remove them? If i remove them, where should they be connected? Sorry for piling up the questions. Thanx again.
~AC |
Originally posted by maxxboost00 thanx Dixit. So, I'm guessing that the fuel lines have to go back to its stock setup, right? And The two hoses that are connected to the FPR should be left alone, correct? What about the electrical wiring? Do I leave the wires connected to the Aux. fuel pump or do I remove them? If i remove them, where should they be connected? Sorry for piling up the questions. Thanx again. ~AC The hose connections for the fuel lines to and from the FPR should be simple. One goes back to the tank and the other is coming off the stock line. Simple. Dixit |
| All times are GMT -7. The time now is 03:11 PM. |
