ok i can't take this anymore....Nissan rotor suck so bad
if you read my previous posts, my rotor has already been resurfaced once and now @ 26k miles I'm having problems with my rotor again.
now my question is what are some of the options I have? I'm thiniking about going aftermarket. As far as I know Stillen has one for us (i have 2k2). Can you guys tell me if there is any other companies out there that makes one for us. And where is the best/cheapest place I can find them. Thank you guys again. |
Re: ok i can't take this anymore....Nissan rotor suck so bad
Change your pads and the way you drive, you are on your brakes too long. Better or even bigger rotors do not mean they are better.
Here are my cracked 13.1" rotors I just replaced....granted I go to the track (Road Course). I have also been to the track with the stock ones an d they never warped. http://members.rogers.com/maxrpm/dir...s/DSCN4092.JPG http://members.rogers.com/maxrpm/dirtyparts.htm Originally posted by BioMaxDDS if you read my previous posts, my rotor has already been resurfaced once and now @ 26k miles I'm having problems with my rotor again. now my question is what are some of the options I have? I'm thiniking about going aftermarket. As far as I know Stillen has one for us (i have 2k2). Can you guys tell me if there is any other companies out there that makes one for us. And where is the best/cheapest place I can find them. Thank you guys again. |
Re: Re: ok i can't take this anymore....Nissan rotor suck so bad
Originally posted by MaxRPM Change your pads and the way you drive, you are on your brakes too long. Better or even bigger rotors do not mean they are better. Here are my cracked 13.1" rotors I just replaced....granted I go to the track (Road Course). I have also been to the track with the stock ones an d they never warped. http://members.rogers.com/maxrpm/dir...s/DSCN4092.JPG http://members.rogers.com/maxrpm/dirtyparts.htm I think this is a gross generalization and can hardly explain the number of brake 'failures'. Not everyone drives the same way nor 'rides' the brakes, so lumping rotor problems under this is an oversimplification. Why would Nissan acknowledge the problem and issue a TSB if they could blame the driving habits that easily? |
Originally posted by MaxRPM Change your pads and the way you drive, you are on your brakes too long. Better or even bigger rotors do not mean they are better. Here are my cracked 13.1" rotors I just replaced....granted I go to the track (Road Course). I have also been to the track with the stock ones an d they never warped. |
Re: Re: Re: ok i can't take this anymore....Nissan rotor suck so bad
Isn't the TSB for 00-01s? The 02s have larger rotors.
Originally posted by jjs Come again? I think this is a gross generalization and can hardly explain the number of brake 'failures'. Not everyone drives the same way nor 'rides' the brakes, so lumping rotor problems under this is an oversimplification. Why would Nissan acknowledge the problem and issue a TSB if they could blame the driving habits that easily? |
Thanks, thats a hairpin turn and I was already past the apex of it and acelerating out of it. The pic is cropped so you can't see the whole thing.
Originally posted by MAX2000JP Thats a cool pic you have in your sig....Shouldnt you be apexing that turn a little more:D What tires do you use at the track? |
Re: Re: Re: Re: ok i can't take this anymore....Nissan rotor suck so bad
Originally posted by MaxRPM Isn't the TSB for 00-01s? The 02s have larger rotors. |
| All times are GMT -7. The time now is 02:41 PM. |
