Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   Help w/Paint Touch Up's (https://maxima.org/forums/5th-generation-maxima-2000-2003/13999-help-w-paint-touch-ups.html)
TX2KMAX Jan 10, 2001 06:54 AM
What's the best way to touch up the paint on my car? I've got some chips on the front of the hood and don't want to just blob on the paint.
Rit Jan 10, 2001 07:00 AM
Somewhere in the BBS thewre is an excellent treatise
on paint touch-up. Maybe you can find it with the search. Basically, you use a toothpick to have the paint fill the chip with a capillary-type action. It takes time and patience, you need to repeat the process several times to overfill the chip, and then wet-sand or compound it back to level. The trick is to take your time.
Weasel Jan 10, 2001 10:57 AM
I was just about to ask this very same question... thanks. :D
theMax Jan 10, 2001 11:21 AM
touch up
Use primer if bare metal is showing before you paint to prevent rust.
UMD_MaxSE Jan 10, 2001 11:32 AM
check ou this link:
http://www.autopia-carcare.com/painchiprep.html
TX2KMAX Jan 11, 2001 04:46 AM
Thanks UMD_MaxSE - that link is exactly what I needed!
UMD_MaxSE Jan 11, 2001 06:43 AM
Thanks man....Anytime :)
Hope you are able to get those chips fixed up nicely.
NYC2SD Jan 11, 2001 10:50 AM
Can you use the regular touch up paint on the guards that run along your door? I have a few small chips from where other people have opened their door into mine. How about the bumpers ?????????
UMD_MaxSE Jan 11, 2001 11:08 AM
Yeah, it should be the same paint.
