What's the diff between 350Z's VQ35 and the Maxima's VQ35 Engine?
Probably a stupid question but what is the difference between the two engines? Other than "one comes in the Z and the other in the Maxima." And other than "one is stronger than the other"..
Is the bore/stroke different? Is the timing advanced? Does it have a better exhaust manifold (header) and exhaust? Does it have a better cat or something? WHAT? :) :confused: |
Re: What's the diff between 350Z's VQ35 and the Maxima's VQ35 Engine?
Originally posted by maxcosity Probably a stupid question but what is the difference between the two engines? Other than "one comes in the Z and the other in the Maxima." And other than "one is stronger than the other".. Is the bore/stroke different? Is the timing advanced? Does it have a better exhaust manifold (header) and exhaust? Does it have a better cat or something? WHAT? :) :confused: |
someone mentioned a difference between the intake manifolds of the two cars. otherwise, the exhaust is different, as seen by the dual outlets and a different exhaust note. also i believe the 350Z makes its peak hp/torque at slgihtly higher RPMs than the Max
i can only imagine it breathes better and farts better. Plus, the computer is designed to do so as well.
as greek max said above, it breathes a lot better than the max. better intake manifold and better exhaust system. maybe tweaked the ECU(im not sure), but i heard the cam lift is higher for the 350z.
- Intake manifold is different.
- Exhaust system is different. - Cams are more aggressive (pretty sure of this) - Variable timing on both intake and exhaust cams (pretty sure of this) - Pistons are probably different (11.2:1 CR vs 10.3:1 on the Maxima) - ECU (duh ;)) |
Originally posted by SteVTEC - Intake manifold is different. - Exhaust system is different. - Cams are more aggressive (pretty sure of this) - Variable timing on both intake and exhaust cams (pretty sure of this) - Pistons are probably different (11.2:1 CR vs 10.3:1 on the Maxima) - ECU (duh ;)) |
Hey Quicksilver....and anyone else that likes to talk specs...
Originally posted by Quicksilver If the bore and stroke were different, I don't think they'd call it a 350Z It's probably pistons, heads, cams, ECU...etc but the 350z and the Maxima engine have the same bore and stroke. but here's a scenario... The BMW M3 has a displacement of 3245cc the Mercedes C320 has a displacement of 3199cc very close in engine size, but the bore x stoke is WAY different. BMW's is 87.0mm x 91.0mm Mercedes is 89.9mm X 84.0mm with 6 cylinders both come very close to 3.2L (they call the M3 3.3L, but it's only 3245cc...it's more like a 3.25) they use different ways to get there power/displacement. if you have a certain size engine...lets say 3.0, you can increase displacement 2 ways...you can increase the bore size, or you can decrease the stroke length....with a larger bore, and a shorter stroke, the engine doesn't have to work as hard for 1 revolution, making it easier to get high rpms out of an engine. but there is a limit to how HUGE you can make the bore, and how short you can make the stroke.. The vq30de revs quicker than the vq35de for this reason...as the 3.0 motor has a larger bore when compared with it's stroke...now it's not larger than the 3.5L's bore, but proportionatly, it allows for better revving.. can anyone explain the "over square" vs. "square" engine thing? I don't know how to explain it. here's another scenario of bore and stroke being different, and the displacement being the same...probably a better analogy that the first, because the engines displacement are almost identical. Honda S2000 (should be called the Honda S1997 because it has 1997cc of displacement) has a bore and stroke of 87.0 x 84.0mm the sr20de engine (found in the G20 and SE-R) has a 1998cc displacement and it's bore and stroke is 86.0 X 86.0mm here's some 3.4/3.5L comparisons :D Taurus SHO 3.4L V8 ....... 82.4 x 79.5 mm using the V8 really show's how different the bore/stroke can be with similar displacement :D Tundra 3.4L V6 ........... 93.5 X 82.0 mm see how much bigger the cylinders are in the 3.4L V6's when compared to the SHO V8? cool huh? GM Lumina DOHC 3.4L V6 ... 92.0 x 84.0 mm the pistons in the 3.4L V6's are WAY bigger than the pistons in the 3.4L V8! GM Grand Am OHV 3.4L V6 .. 92.0 x 84.0 mm notice how the OHV and DOHC GM engines probably used the same friggin block...GO GM! great engineering! :rolleyes: Diamante 3.5L V6 ...... 93.0 x 85.8 mm 300M 3.5L V6 .......... 96.0 x 81.0 mm 350Z 3.5L V6 .......... 95.5 x 81.4 mm Maxima 3.5L V6 ........ 95.5 x 81.4 mm 3.5RL 3.5L V6 ........ 89.0 x 86.0 mm Intrigue 3.5L V6 ...... 89.5 x 92.0 mm -vq just wanted to clarify... |
Re: Hey Quicksilver....and anyone else that likes to talk specs...
Originally posted by VQMAN actually an engine can still displace 3500cc's and have a different bore and stroke... but the 350z and the Maxima engine have the same bore and stroke. but here's a scenario... The BMW M3 has a displacement of 3245cc the Mercedes C320 has a displacement of 3199cc very close in engine size, but the bore x stoke is WAY different. BMW's is 87.0mm x 91.0mm Mercedes is 89.9mm X 84.0mm with 6 cylinders both come very close to 3.2L (they call the M3 3.3L, but it's only 3245cc...it's more like a 3.25) they use different ways to get there power/displacement. if you have a certain size engine...lets say 3.0, you can increase displacement 2 ways...you can increase the bore size, or you can decrease the stroke length....with a larger bore, and a shorter stroke, the engine doesn't have to work as hard for 1 revolution, making it easier to get high rpms out of an engine. but there is a limit to how HUGE you can make the bore, and how short you can make the stroke.. The vq30de revs quicker than the vq35de for this reason...as the 3.0 motor has a larger bore when compared with it's stroke...now it's not larger than the 3.5L's bore, but proportionatly, it allows for better revving.. can anyone explain the "over square" vs. "square" engine thing? I don't know how to explain it. here's another scenario of bore and stroke being different, and the displacement being the same...probably a better analogy that the first, because the engines displacement are almost identical. Honda S2000 (should be called the Honda S1997 because it has 1997cc of displacement) has a bore and stroke of 87.0 x 84.0mm the sr20de engine (found in the G20 and SE-R) has a 1998cc displacement and it's bore and stroke is 86.0 X 86.0mm here's some 3.4/3.5L comparisons Taurus SHO 3.4L V8 ....... 82.4 x 79.5 mm using the V8 really show's how different the bore/stroke can be with similar displacement :D Tundra 3.4L V6 ........... 93.5 X 82.0 mm see how much bigger the cylinders are in the 3.4L V6's when compared to the SHO V8? cool huh? GM Lumina DOHC 3.4L V6 ... 92.0 x 84.0 mm the pistons in the 3.4L V6's are WAY bigger than the pistons in the 3.4L V8! GM Grand Am OHV 3.4L V6 .. 92.0 x 84.0 mm notice how the OHV and DOHC GM engines probably used the same friggin block...GO GM! great engineering! Diamante 3.5L V6 ...... 93.0 x 85.8 mm 300M 3.5L V6 .......... 96.0 x 81.0 mm 350Z 3.5L V6 .......... 95.5 x 81.4 mm Maxima 3.5L V6 ........ 95.5 x 81.4 mm 3.5RL 3.5L V6 ........ 89.0 x 86.0 mm Intrigue 3.5L V6 ...... 89.5 x 92.0 mm -vq just wanted to clarify... :bowdown: The engine man comes to rescue! :bowdown: ~limsandy |
:eek: :bonk: :bowdown:
[QUOTE]Originally posted by VQMAN
if you have a certain size engine...lets say 3.0, you can increase displacement 2 ways...you can increase the bore size, or you can decrease the stroke length....with a larger bore, and a shorter stroke, the engine doesn't have to work as hard for 1 revolution, making it easier to get high rpms out of an engine. And this, folks, is why a 383 Stroker motor is so popular in domestic hot rods. I believe you take a 400 crank and place it in a 350 block. The new crank has rod journals that are futher away from the centerline of the crank than a regular 350, which gives the motor more leverage (torque). Then you bore the motor out and put bigger pistons in. Finally, you insert shorter connecting rods. So you end up with a motor that has as shorter stroke than a 400 (higher RPM capability) but is larger in displacement than a 350...its a real beast. can anyone explain the "over square" vs. "square" engine thing? I don't know how to explain it. I think the term "undersquare" means a motor has a larger bore than stroke. I believe the BMW 330Ci is an example. Jesse |
Originally posted by Y2K2Driver I believe the conclusion at that time was that the only difference was intake, exhaust, and ecu. |
Re: Re: Hey Quicksilver....and anyone else that likes to talk specs...
Originally posted by 02MaximizedVQ can anyone explain the "over square" vs. "square" engine thing? I don't know how to explain it. I think the term "undersquare" means a motor has a larger bore than stroke. I believe the BMW 330Ci is an example. Jesse Oversquare means larger bore than stroke. Undersquare means larger stroke than bore. The 3.0 VQ is actually one of the most oversquare production engines I've ever seen. 3.66in bore x 2.89in stroke. One of the few production engines to have such a hugely oversquare design, yet it remains so torquey. And thanks in part to the very low pistons speeds due to the short stroke, the engine can maintain high revs and be very smooth like it's nothing. In comparison, the J30A1 engine in my 2001 Accord V6 was 3.39 x 3.39 and completely torqueless, but that was due to the cams, not the internal geometry of the engine. |
Originally posted by SteVTEC If the intake manifold, exhaust system, and ECU are the only changes, then how do you explain the 11.2:1 compression ratio? http://www.nissanperformancemag.com/...2/zspecstable/ |
Originally posted by Y2K2Driver Easily, it doesn't. Here is a link to NPM specs on the 350Z. I agree that it may not mean much b/c you could equally find sites which show 11.3:1 as well, though they usually lack alot of other info indicating that it was compiled before Nissan released the car, thus speculation. The only way to be sure is to find someone with a 350Z shop manual. http://www.nissanperformancemag.com/...2/zspecstable/ http://www.nissannews.com/nissan/200...0z/specs.shtml :mad: But then again, I've seen some error's on even Nissan's site as well. :jeffy: So where the hell is this 11.2/11.3 coming from? Yup, I guess we need a shop manual then. ;) |
Alll of this information has been looked up by DAVE B and myself.
Pistons: Same part # Cams: Same part# Intake: Obviously different Exhaust: Different Injectors: Different part# There are no internal differences between these engines. They have the same 95.5mm bore and the same 81.4mm stroke. They use the same pistons, rods, cams, block and im pretty sure the exact same heads too. The CR's are the same @ 10.3 from all the data I have read (from car mags, and various tech info) If indeed it is different then dozens of sources have posted it incorrectly. The 350Z engine simply doesn't make enough power to prove otherwise. Emax and some other have proven that with simple bolt ons we can get the exact same 230+ whp that the 350Z has. It shoudl be obvious enough from knowing that you cna take a stock 2002 Maxima and put 200 - 205 hp on the ground and add 10hp to that from simply removing the oem filter cartridge. The only difference is that we (Maxima drivers) have the asphyxiated version of the engine. |
Re: Re: Re: Hey Quicksilver....and anyone else that likes to talk specs...
Originally posted by SteVTEC That's backwards actually. Oversquare means larger bore than stroke. Undersquare means larger stroke than bore. The 3.0 VQ is actually one of the most oversquare production engines I've ever seen. 3.66in bore x 2.89in stroke. One of the few production engines to have such a hugely oversquare design, yet it remains so torquey. Then there is the Ford 289 from the earlier Mustangs. 4.00" x 2.87" (101.6mm x 72.9mm) |
But the 350Z still has VTC on both the intake and exhaust cams, correct? The Alty/Max/Path I think only have it on the intake came side.
Originally posted by SteVTEC But the 350Z still has VTC on both the intake and exhaust cams, correct? The Alty/Max/Path I think only have it on the intake came side. Yes and no. The engines all have the save type of chain setup. The variable device is only located on the intake cam but the exhaust cam is slaved off the intake cam via a separate chain. Therefore the Maxima and Altima have the same intake and exhaust cam variable timing as the 350Z. The lob separation angles are always going to be the same no mater what the timing is. |
Originally posted by SteVTEC That's backwards actually. Oversquare means larger bore than stroke. Undersquare means larger stroke than bore. The 3.0 VQ is actually one of the most oversquare production engines I've ever seen. 3.66in bore x 2.89in stroke. One of the few production engines to have such a hugely oversquare design, yet it remains so torquey. And thanks in part to the very low pistons speeds due to the short stroke, the engine can maintain high revs and be very smooth like it's nothing. In comparison, the J30A1 engine in my 2001 Accord V6 was 3.39 x 3.39 and completely torqueless, but that was due to the cams, not the internal geometry of the engine. this guy doesn't have to use Google...I do... -vq |
Originally posted by SR20DEN Yes and no. The engines all have the save type of chain setup. The variable device is only located on the intake cam but the exhaust cam is slaved off the intake cam via a separate chain. Therefore the Maxima and Altima have the same intake and exhaust cam variable timing as the 350Z. The lob separation angles are always going to be the same no mater what the timing is. The whole point of having phase variable intake and exhaust cam setups is so that you can vary the amount of overlap independently for either emissions/economy, or performance. You're saying that the lobe separation angles (between intake and exhaust lobes?) are always the same, or did I just not understand you correctly? :confused: |
Re: Re: Re: Re: Hey Quicksilver....and anyone else that likes to talk specs...
Originally posted by VQMAN :bowdown : the REAL engine man comes to the rescue! :bowdown: this guy doesn't have to use Google...I do... -vq |
Originally posted by SteVTEC Now something sounds screwy here. :jeffy: The whole point of having phase variable intake and exhaust cam setups is so that you can vary the amount of overlap independently for either emissions/economy, or performance. You're saying that the lobe separation angles (between intake and exhaust lobes?) are always the same, or did I just not understand you correctly? :confused: Also, if it were able to adjust the I/E lob separation angles then wouldn't it have to have cam timing sensors on the exhaust cams too? Im certain it only has the sensors on the intake cams. |
Re: Re: Re: Re: Re: Hey Quicksilver....and anyone else that likes to talk specs...
Originally posted by VQMAN GM Lumina DOHC 3.4L V6 ... 92.0 x 84.0 mm the pistons in the 3.4L V6's are WAY bigger than the pistons in the 3.4L V8! GM Grand Am OHV 3.4L V6 .. 92.0 x 84.0 mm notice how the OHV and DOHC GM engines probably used the same friggin block...GO GM! great engineering! :rolleyes: this GM geek at work a few years ago was talking about what a marvel of engineering the 3.4L DOHC V6 was...jeez....what a waste... -vq |
Originally posted by SR20DEN Yeah thats what I was saying. Find the cutout pic of the 350Z engine and it becomes pretty clear. The VQ35 in that form still only has the variable unit on the intake cam only. Just like the previous 300ZX and the current Maxima and Altima. Also, if it were able to adjust the I/E lob separation angles then wouldn't it have to have cam timing sensors on the exhaust cams too? Im certain it only has the sensors on the intake cams. |
Originally posted by VQMAN did anyone even notice this part of my post? this GM geek at work a few years ago was talking about what a marvel of engineering the 3.4L DOHC V6 was...jeez....what a waste... -vq |
Originally posted by Sam03 Do you happen to know the cc's of the Maxima,(3.5) and the cc's of the Z's injectors? |
Originally posted by SteVTEC All those 2.8/3.1/3.4 engines are all based on the same block I think, and they all suck. The 3800 is much better. That depends on who you ask. The 3800 (L67) is a crustly old boat anchor that needs to die and GM agrees. All of the new 'Global' engines will be based on the 60º design which is much more modern. There will be a 3.5 Liter 2 valve version and a 3.6 Liter 4 valve version. The bore spacing on this engine is so much that there will one day be a 3.9 liter version and will weigh less than and make tons more power than the L67. The ONLY reason the 3800 is popular is because GM added forced induction to them on several occasions. |
Originally posted by SteVTEC All those 2.8/3.1/3.4 engines are all based on the same block I think, and they all suck. The 3800 is much better. hasn't the 3800 been around since the late 60's? -vq |
Originally posted by SR20DEN The ONLY reason the 3800 is popular is because GM added forced induction to them on several occasions. -vq |
Originally posted by SR20DEN Im in the process of trying to get that information. Im going to arrange to have a Maxima injector sent to RC engineering to get flowed. |
Originally posted by VQMAN that's not the ONLY reason...another reason it was popular, is because almost EVERYONE that drives has owned a car with one...they've been around since the dawn of time... -vq |
Originally posted by VQMAN yeah, that 2.8 and 3.1 used to be in the Cavalier Z24...before the 2.4L DOHC....they were real dogs. hasn't the 3800 been around since the late 60's? -vq 3.1 is a dog eh? My 3.1 managed to push my 3500lb fatass down the quarter at 15.51@87.. you only managed a 14.99 in your lighter car.. talk about the pot calling the kettle black.. :rolleyes: |
Originally posted by GPXSS 3.1 is a dog eh? My 3.1 managed to push my 3500lb fatass down the quarter at 15.51@87.. you only managed a 14.99 in your lighter car.. talk about the pot calling the kettle black.. :rolleyes: |
Re: Re: Re: Re: Re: Re: Hey Quicksilver....and anyone else that likes to talk specs...
Originally posted by Sam03 He ran his times at altitude, are you familiar with what that can do to times? GPXSS and I ran our times at about 500 feet altitude. The point he was making is that no matter what, 14.99 is not a good representation of a 3200 pound car with 200 fwhp 225 lb. ft. tq. |
can anyone explain the "over square" vs. "square" engine thing? I don't know how to explain it. I think the term "undersquare" means a motor has a larger bore than stroke. I believe the BMW 330Ci is an example. Jesse [/B][/QUOTE] no.......Larger bore than stroke is OVERSQUARE. Most super high performance engines (high HP/Liter) have that configuration. (F1, motorcycle...etc) I can't remember the reason behind it. But someone mentioned high rpm capability and that is definitely one of the reasons.:cool: |
Re: Re: Re: Re: Re: Re: Re: Hey Quicksilver....and anyone else that likes to talk specs...
Originally posted by SR20DEN GPXSS and I ran our times at about 500 feet altitude. The point he was making is that no matter what, 14.99 is not a good representation of a 3200 pound car with 200 fwhp 225 lb. ft. tq. |
| All times are GMT -7. The time now is 04:15 AM. |
