Who is using 235/45 17's on stock 2k rims?
And what ride diference is there if any ? Thnks, Ecko |
Anyone out there?
I cant even use the search feature to help me out so I'm counting on you guy's Also has anyone used the Cooper oem replacement's? |
I can't answer your question but the search on the test site is working, http://test.maxima.org
Running HTR+ 235's on stock 17's. Only differences are that they're cheaper than the alternatives, look good when you look at the car from the rear, and they're better than the nitto's I had before.
I haven't had any problems and don't anticipate any. No bulge on the rims either. Since you can't search, just scroll throught the pages and do a text search (CTRL+F) for "235/45", "17", "stock", "rim", etc...not as efficient as the search function, there are a lot of posts on this. |
I had the 235-45-ZR17 Nitto 555 on the car for about 20K miles before I switched to 235-40-18s. They fit the stock 17 inch rims w/o any problems. But keep in mind that the wheel gap will be a lot more if you're not lowered. Also, u'll definitely feel a difference in the ride too as the side walls are smaller than the Stock size. You'll feel the bumps a little bit more and I think you'll have little bit more road noise than before. Overall, I was happy with the with the size as the stock tires sucked. Hope this helps.
Originally posted by Smokin' X-press before I switched to 235-40-18s. 18's ? |
I am running Kumho Ecsta MX 235/45/17 on my stock 2K2 wheels and I have had no problem. The look better and bandle better as well.
louder, rougher, STICKIER. i've had that size since blowing two of my potenzas within a month of each other. the tradeoffs are worth it in my opinion altho i'll prolly go back to stock size with the new kumhos next time around. i'm on the yokos now and i love em. no problems.
I'm running 235/45/17's on stock rims & they're great. I bent my right front wheel w/the factory 225/50/17's 7 now I can't tell at all. it fills in the gap completely. Also, they look the same size as far as sidewall height.
I am with no problems.
Originally posted by Sonic I am with no problems. |
Originally posted by Eenis Running HTR+ 235's on stock 17's. Only differences are that they're cheaper than the alternatives, look good when you look at the car from the rear, and they're better than the nitto's I had before. I haven't had any problems and don't anticipate any. No bulge on the rims either. Since you can't search, just scroll throught the pages and do a text search (CTRL+F) for "235/45", "17", "stock", "rim", etc...not as efficient as the search function, there are a lot of posts on this. How do you like HTR+ tires so far? |
Running Falken Ziex 512's 235/45/17 on Stock 17's. COming from Blowtenzas ride is actually improved for me. They stick very well in rain or shine. I love 'em.
Originally posted by Dany Hey I am trying to decide between HTR+ and ContiExtremeContact. Both in 235/45R17 size. How do you like HTR+ tires so far? |
What about 235/50-17 on stock 17? Can I put 235/50-17 on stock 17 with no problem?
Originally posted by MaxMafia What about 235/50-17 on stock 17? Can I put 235/50-17 on stock 17 with no problem? |
235-45-17 front----245-40-17 rear.....no problems whatsoever looks better to me.
Originally posted by maseo77 235-45-17 front----245-40-17 rear.....no problems whatsoever looks better to me. I bet those 245 look nice and wide from the back. |
Originally posted by Dany Now this is cool. Like BMW, wider tires in the back nmd narrower in the front. I bet those 245 look nice and wide from the back. |
Originally posted by maseo77 235-45-17 front----245-40-17 rear.....no problems whatsoever looks better to me. Originally posted by Dany Now this is cool. Like BMW, wider tires in the back nmd narrower in the front. I bet those 245 look nice and wide from the back. useless for a FWD application...the front wheels are what drive the car....to have wider tires in back when not used is :007: RWD applications can only make use of this |
I've got Yoko 235/45/17's on stock 2k 17 rims and they STICK. They are all-weather, little rougher but love the holding power.
i ride bigger in the back for looks plus the 245 dunlop sp 9000 were free, what would you do with free tires u :007:
check my sig
| All times are GMT -7. The time now is 12:32 AM. |
