Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   cons of tsb's (https://maxima.org/forums/5th-generation-maxima-2000-2003/185265-cons-tsbs.html)
Maxnut Oct 7, 2003 02:30 PM
cons of tsb's
I am taking my car in tomorrow and plan on asking the dealer to do several tsb's including, lack of power, xenon headlamp theft deterrent kit, hood shudder, and wind noise. Has anyone had any bad experiences after having a tsb done? I am mostly concerned about the hood shudder, wind, and xenon tsb's. I do not want to drive out of the dealership worse off than when I drove in.
92 SE-R 02 SE Oct 7, 2003 02:36 PM
i took my 02 for almost all the things you asked for. they fixed the wind noise, hood rattle (man it was BAD!!!) the HID kit i wont pay for, and my 02 doesnt have the lack of power. dealers know about most of the problems, so all should work out...
IgS Oct 7, 2003 02:53 PM
im thinking to take it in for wind noise....how long did it take? im asking because my shedule is pretty busy. :rolleyes:
thx
-IgS
IceY2K1 Oct 7, 2003 03:59 PM
Besides the "Can't duplicate" or "That's NORMAL" lines, they can AND will break sheit, scratch sheit, and fuk up 2-3 other things for every one they fix. At least that's my experience.
Anyways, I'd have them perform the lack of power TSB, forget about the "theft deterrent":rolleyes: kit, and perform the hood and wind noise TSBs yourself.
Good luck!
Maxxxed Oct 7, 2003 05:04 PM
I own an 03 Max SE. Occasionally my car seemed sluggish, I asked them to do the "lack of power" TSB. He looked up his computer and told me that my car will qualify for reprogramming but I will still have the same old MAF... Before doing it, he told me that our cars are sluggish and its normal. He also told me that if they reprogram my car will burn more fuel etc. I asked him to go ahead with the update.
I think both our engines do not qualify for MAF replacement... so I am not sure "lack of power" TSB will do much. I did find the car to be running a bit smoother and more responsive, but I think I need a week to judge the difference...
bluemaxx Oct 7, 2003 05:26 PM
I took my 2k1 AE in for the fuel cut off tsb and it was never the same after that.
When I bought the car it had personality, ran like a spotted assed ape. After the TSB it was ho/hum performance. As far as I know the SE and AE had the same engine, AE advertised 5 extra HP from the muffler. I'm skeptical about the muffler though. I think they tweaked the ECM of the AE and the TSB programmed it like any othe SE.
After the TSB it was disappointing. I even had them bump the timing to 17btdc, no help.
ECM TSBs scare me.
trey Oct 7, 2003 07:34 PM
Hey maxxxed, I'm trying to figure out if my car needs the "lack of power tsb". Was your car sluggish when acelerating from a stop or what?
Its like i want to get something if its entitled to me but i'm not sure if i need it ahah.
Maxxxed Oct 7, 2003 08:10 PM
trey, yeah it was sluggish when accelerating from stop. Sometimes engine would run a bit rough like its pulling extra weight or something... I just had this TSB done today, overall I feel some difference, maybe its just in my head. If your dealer agrees to do it, just get it done... you'll "feel" a little better knowing that you used a little bit of your warranty :)
IceY2K1 Oct 7, 2003 08:20 PM
The AE has a different ECU part number.
ECM TSBs scare me.
trey Oct 7, 2003 08:22 PM
Thanks man, i'm gonna wait a while since my car seems perfectly normal, i haaaaaate bringing my car in anways
bluemaxx Oct 7, 2003 09:20 PM
But was there a different TSB for AE fuel cut off vs. SE fuel cut off? I don't think so. I think they reflashed my ECM with the regular code thus wiping out any advantage that Nissan may have tuned into the AE ECM.
I still don't buy the 5 extra HP due to gizmo valve in the muffler krapp.
IceY2K1 Oct 7, 2003 11:28 PM
Me neither, but DAVEB says they are indeed different. What the difference is he doesn't know.
Do you have a OBD scanner by chance? Mine tells me the part number and I'd like to know what yours has. DAVEB can also tell you from your VIN# if you're curious.
TimW Oct 8, 2003 09:31 AM
cons of tsb's?
You mean the cons that perform them? :)
sloppymax Oct 8, 2003 10:50 AM
i would like to know the difference and i do have obd2 software.
IceY2K1 Oct 8, 2003 11:10 AM
Call DAVEB at (888)254-6060 to give him your VIN#. Hopefully, he isn't busy.:wall:
Anyways, on my Alex Pepper OBD software, I can do a VIN, CVIN, etc... check, but only one works and it happens to return the ECU part number. Can you do the same?
Craig2kGLE Oct 8, 2003 11:34 AM
The con of having TSBs done is that most dealers either a) don't care, b) don't know what they're doing, or c) all of the above.
I had the wind noise TSB done. I'm still trying to get the silicone gunk off my leather seats, and I still have to scrub it from my windows whenever I decide to lower them and put them back up.
I had the brake judder TSB done, and the problem returned a couple of weeks later. They didn't replace the pads, even though the TSB calls for it, because "that's just a guideline, and we choose what to follow."
I had the 1-2 slow shift (auto tranny) TSB done, and the car has shifted even slower since the "fix". As a consolation prize, the dealer scratched the interior driver's door panel with a screwdriver.
Come to think of it, even an oil change comes with benefits. Last time I had scratches on the car that weren't there before. I consider a successful Nissan service experience one that does not cause additional damage to the car.
YMMV.
Darth Vader Oct 8, 2003 11:42 AM
Just had the hesitation TSB done today. Very happy with service and results.
mattattax Oct 9, 2003 11:06 PM
Can you get a TSB done if you're past warranty?
MaximaDisciple Oct 10, 2003 10:14 AM
You'll probably have to pay for it. :gotme:
Maxxxed Oct 10, 2003 10:46 AM
If you are past warranty period, you are on your own - just slightly different from when you had warranty. :grinno:
Maxxxed Oct 14, 2003 04:25 PM
... I did find the car to be running a bit smoother and more responsive, but I think I need a week to judge the difference...
OK, I had "lack of power" TSB done about a week ago. They updated the software and I am not sure if they replaced my MAF. He highlighted the part number 237106Y314 and commented as "updated #". I am not sure if this is a new MAF or my old one...
The first three days (after I had the TSB done) my ride was just amazing. My car was very quick and responsive. Automatic gear shifting was smooth, everything was just great... Slowly it lost its edge and now its back to being sluggish. I have no idea if this is mechanical issue or the software or the MAF itself. Does anyone have any idea why this is happening? Do I have to buy different MAF and install it myself to achieve better results?
IceY2K1 Oct 14, 2003 04:47 PM
Using past Nissan TSB ECM part numbers listed on a TSB I have, it says the 6Y31X is a "Vehicle with an updated airflow meter", so I think you've got a new one.
I would perform the ECU reset procedure and Drive-by-wire reset procedure shown in the How-To sticky or search for the thread. If that gives you back the "amazing", "quick and responsive" feel I'd find out what the dealer has to say about that.
Maxxxed Oct 14, 2003 05:59 PM
IceY2K1, thanks man for your help... I will reset the ECU tomorrow. How do I do Drive-by-wire reset? I did not find anything about that.
Also, I forgot to add that when accelerating the gas pedal resists against push and I have to apply more pressure to accelerate. I am not sure if this is a related problem...
Maxxxed Oct 15, 2003 11:21 AM
Can someone tell me how to do Drive-by-wire reset... thx.
