02 er's and 03 er's what do you keep your trip computer on?
I was just curious what mode do you keep your trip computer on, I usually keep mine on the temp. display ocassionally going to DTE. :squint: What about you guys?
they say great minds think alike ;) I do the same....99% of time temp display, other 1% DTE (after I fill up-like to see if my gas mileage goes up or down as my miles pack on) |
i do the same thing as u... on temp...
I do the same as well.
Temp display 90% of the time as well. It was gas mileage about 50% of the time, but I started to notice everytime I cleared it and drove it always returned to the same area...which was 24.3-24.5 mpg. I thought...wow this car gets great gas mileage for this size engine and performance. Then, after a couple fill ups and calculating the gas mileage the REAL way and the only REAL accurate way, I realized I was really getting between 22-23 mpg on average. Still really good, but consider at least half or more likely 60% of driving in LA is on a freeway (even if it's only a couple miles away. So I quickly learned the gas mileage computer was not realistic and therefore it made no sense for me to keep it on that setting. I did notice one thing about it though. I installed a K&N filter last year, and after a fill up the computer increased .2 mpg to the 24.5 from the 24.3 it usually sat on. I don't trust th distance to empty anyway. I try to always fill up before it gets below 1/8 tank. |
Yep - temp mostly, DTE the rest of the time.
Temp all the time.......Except for when the DTE starts flashing. :slap:
1234 |
DTE, Temp are the most common I am on
Temperature.... why? Because it's almost winter and I'd like to know if there is black ice on the road.
~limsandy |
temp ?
I live in Arizona and the Temp guage does not go that high. I guess Nissan neglected to take us poor melting folks into consideration. A minor oversite they are sure to fix in the future. Maybe they will also come out with an Arizina Edition that comes with an airconditioning that won't only work in the winter, and even airconditioned seats instead of heated. |
Temp & DTE...The mpg one is completely inaccurate, and the time thing would really only be useful on a road trip or something.
mine doesnt work sinse i put in my bummping system....
temperature
Originally Posted by gtbigup
There is a way to fix that after installing an aftermarket radio.Do a search you should find it.Just have to connect two wires left open after radio install.
Most of the time DTE but if i'm going on a longer trip I usually go with MPG.
Temp and DTE.
Pedro |
Mine stop working ever since I put in an after market head unit. Dose anyone know if I get the PAC steering wheel controler would it make it work again?
DTE 99% of time
Temp most of the time dte when below 1/4 tank.
In my opinion, the DTE to very accurate. I've never ran out of gas, but i've gotten that needle so far down after the DTE= ---- (around 20miles left) that i'm a true believer now.
I hate having to reset my MPG. How often do u guys reset it because it seems to get stuck at a certain point, such as when driving in the city, and refuses to increase, such as when u get on the highway? |
I use temp and DTE...MPG is totally off (by up to 4 MPG in some cases). And I really don't want to know how much time I've spent in the car on this tank. It's depressing...
Ever notice your gas milage (yes the trip computer # that's 4 MPG higher than reality) steadily decrease on a road trip from over 30 to below 20 in under two hours? And only then realize you've actually been reading the DTE figure the entire time, even inserting a decimal point that isn't there? Um, I bet that would sure make one feel pretty stupid...
DTE, haven't tried TEMP yet... Interest as most of you guys have it on TEMP...
I've never done that. Never confused the two. It clearly says DTE right under it, and MPG right under the other.
How can you imagine that the DTE is MPG and there is a Decimal point? :tardsmash |
Dte & Temp 50/50
Another vote for temp.
Is there a way to reset the MPG??
I'm on temp 99% of the time. I like to know what the temperature is going to be like when I step out of my car. Usually hot and humid since I live in Houston. |
Originally Posted by bremner44
Hold down the 'TRIP' button on your steering wheel for a few seconds while it's on MPG and it will reset it.
I'm on temp 99% of the time. I like to know what the temperature is going to be like when I step out of my car. Usually hot and humid since I live in Houston. how lond do you spend in your car ? I would not think that the temp would change more then 1-3 degrees within most trips |
I drove from Houston to Montana and then back again a couple months ago. The temp changed about 6 degrees a day (2 day drive). The DTE and MPG seem very inacurate to me so I only check them once in a while. Maybe I'll just put it on the timer and watch the seconds add up. Fun stuff.
temp
temp
temp and temp -vq |
| All times are GMT -7. The time now is 05:35 PM. |
