Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   what is the VQ35DE's Compression (https://maxima.org/forums/5th-generation-maxima-2000-2003/197080-what-vq35des-compression.html)
02 SunliTMaxima Dec 13, 2003 05:07 PM
I was thinking about a custom turbo application but isnt the compression on our engines like really high. Cause High Compression + boost = Boom
03BlkSETE Dec 13, 2003 05:28 PM
compression is 10.3
Same as the 350z which is safely (for the most part) running boost with a variety of aftermarket applications.
NYC TAR Dec 13, 2003 05:46 PM
the compression ratio is 10.3. that is very hi. It is higher than the 330i engine. That is why premium gas is a must.
MrGone Dec 13, 2003 08:39 PM
10.3:1 is a cake walk. Try 13.5:1 :wall:
F23A4 Dec 14, 2003 08:47 AM
Well, the Greddy turbo 350Z is running a pretty conservative 5.6psi (resulting in 334whp), probably due to the VQ's high compression. My hunch (non-scientific) is that if you run less than 1/2 bar boost, you should be OK. just my $.02
