Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   Exhaust question's? (https://maxima.org/forums/5th-generation-maxima-2000-2003/214679-exhaust-questions.html)
thomasd cook Mar 9, 2004 08:56 PM
Exhaust question's?
I want to get a budget 2.5" B-pipe from my local shop. I would like to try and keep the same muffler but I don't think it would make much of a difference if I swap the B-pipe to 2.5" but the muffler inlet is only 2.25". Is it worth it to swap the B-pipe leaving the factory muffler or should I just swap the muffler out with the B-pipe? I'm contemplating getting the Powertech Magnaflow muffler. Also should I get the B-pipe with or without resonator? How will this affect the noise output? I don't want the noise to increase much.
The guy also said that unless I plan on Supercharging it's not worth it to swap out exhaust. I'm kicking around the idea of getting a 50 or 75 shot Wet kit in the future. And my mods to this date are intake & UDP.
Ammi Mar 9, 2004 09:46 PM
exhaust systems on NA cars don't add much hp.
crispykid717 Mar 9, 2004 11:30 PM
Ammi is right. A catback won't add much hp...but when you combine that with a y-pipe you can get some pretty decent hp gains from that whole setup. b-pipe w/ resonator will be less noisy than a b-pipe w/o a resonator.
thomasd cook Mar 9, 2004 11:45 PM
How much does the resonator affect the flow or gains?
Ammi Mar 10, 2004 05:26 AM
if you haven't done any mods, I would go w/ Y Pipe instead of exhaust system. You'll definitely see some gain in power.
