Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   grinding brakes, then goes away and it ain't surface rust that I can see (https://maxima.org/forums/5th-generation-maxima-2000-2003/217562-grinding-brakes-then-goes-away-aint-surface-rust-i-can-see.html)
MNMaxi Mar 22, 2004 03:07 PM
I have an early build 2000 SE Auto with 64K miles. Brakes are 100% original. I'm getting a nasty grinding & scraping noise from what sounds like the rear, but it only does it once or twice during my 1st and 2nd stops after the car sits parked. I'm well aware of this happening with "surface rust" on the rotors and this ain't the deal, at least it ain't visible like after the rain. I can leave the car for a couple hours and it does it again, then goes away after a stop or two. Usually squeaks in front and scrapes in rear and then work fine. Any ideas? I've now tried pumping my brakes 3 times in park after I started the car and before I backed up and hit the brakes to maneuver out of a parking spot and it seemed like it actually helped. I'll try again to see if I'm loony. Any ideas? Could it be invisible surface rust? There are no bad grooves in the rotors, no shimmy during hard stops, just a bad grind or scrape that sounds terrible and then goes away. Pads from what I can tell look like they have a decent amount left, especially in the rear, but I'm not 100% sure I'm looking at them correctly either. Besides the stealer, where would people recommend brakes from? Midas, Tires Plus, local ma and pa,etc?? Just looking for opinions.
Lastly, what are they running this site on, an old 486???
BigDogJonx Mar 22, 2004 03:16 PM
Check the rotor with the wheel off, you may be grinding the rotor with a totally worn pad.
It could be coming from the back pad of the rear so you wont see it just just looking at it, you will need to remove the wheel.
Dixit
