SLIP, TCS OFF and ABS lights turned on my 01 today
Old 05-09-2004, 05:31 PM
2001SE's Avatar
What can I do?
I rested the comptuer and nothing happend, what else can I try other then to take it to the dealer?
2001SE is offline
Old 05-09-2004, 06:10 PM
IMBOUTTOBUSTSOMEGHOSTS
sloppymax's Avatar
Originally Posted by 2001SE
What can I do?
everytime i have seen someone post this, it ended up being a coil(s) failure. you should take it to autozone and have the code pulled. most likely it will be P1320 which would indicate a possible coil failure. there is no point in resetting the ecu until the repair is done because it will just keep cycling the code out til its fixed. eventually, the light will go away but the code is stored in the ecu. if you do not have an autozone near by then you will have to either take it to a dealer or a local shop with an obd2 diagnostic machine.
sloppymax is offline
Old 05-09-2004, 06:18 PM
2001SE's Avatar
what does the TCS and ABS have to do with coils?
2001SE is offline
Old 05-10-2004, 03:28 AM
sloppymax's Avatar
i wish i knew why it was wired like that. there is another thread in here right now about the same issue and the same advice was given that it was the coils. 99-00-early build 01 all seems to have coils with high failure rates. check out the 4th gen section sometime and you will 99s posting up the same info about all 3 lights going off and it being coils. good luck.
Old 05-10-2004, 05:06 AM
CRIS_Y2K_SE's Avatar
i have the same problem i took it to the nissan dealer and they came up with a ignition failure so im getting new coils today.
CRIS_Y2K_SE is offline
tsi6001
10-03-2022 10:23 PM
AnsonJ
06-02-2017 01:35 PM
SmokinMax02
18
09-11-2015 12:25 AM
2k0to2k3
08-18-2015 09:59 AM
Trin1j23
08-12-2015 08:31 PM
Quick Reply: SLIP, TCS OFF and ABS lights turned on my 01 today
