6-spd's only
Any of you guyz out there have an issue with the shift knob, loose or not staying aligned........it's kinda crooked and I can unscrew it, and screw it back on.......just wanted to see what you guyz have done.....
Preesh Deckdout |
I havn't had a problem
I used Loctite two years ago and had no problem since.
no problem with mine
Mine came loose a while ago. I just adjusted the way I handle the shifter and havent had a problem since.
preesh again guyz!!!
All you have to do it tighten it one more turn. It will start getting tight when the front is pointing towards the passenger seat. Keep turning it till it rotates all the way around. Once it is pointing straight ahead it will never move again. I did mine about a year and a half ago and it hasn't moved since.
Mine has a little hex screw facing the ashtray that looks like it is keeping it attached to the shifter (?).Looks factory, but who knows.
Yep...
Just twist that mofo real hard one more turn. It will never move agian, unless you really really want it to. |
| All times are GMT -7. The time now is 09:54 AM. |
