Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   seat won't go up HELP! (https://maxima.org/forums/5th-generation-maxima-2000-2003/228986-seat-wont-go-up-help.html)
the paragon May 15, 2004 08:00 AM
Here is the situation. basically pushed the seat to recline backwards for a nap. when i woke up, i couldn't postion the seat back forward. not sure if a motor burned out or a wiring problem. bottom half of the seat still moves up and down, just the back part doesn't come up forward. passenger seats works fine. any ideas?
custommaximaSE May 15, 2004 11:33 AM
Try to move it forward if you hear the motor then the motor its fine just try and move it by hand don't force it too much. it might be stuck.BTW there is two motors in each seat one for (up+down)and one for(forward+backward).If nothing happen take the seat off 4 screws on the corners lift the seat up just a little from the front and take a look under the seat.
It happen to me it was the motor but i did not pay a $ ,it was under warranty.
the paragon May 16, 2004 02:31 PM
weird thing is no sound is coming from the motor. should i swap the motor from the passenger side? is that possible? what else can cause the malfunction?
aussie983 May 16, 2004 05:55 PM
i think there was a tsb for the drivers seat... Check stickies.
95gxe May 16, 2004 07:19 PM
TSB Problem
Check the TSB info @ http://www.alldata.com/
I saw your problem listed there.
the paragon May 17, 2004 11:01 AM
the TSB link doesn't work . anyone have the link to it? tks
Larrio May 17, 2004 11:43 AM
" 02-001C JUL 02 Interior - Driver's Seat Won't Move Forward/Backward "
i don't think it applies to you
http://www.alldata.com/TSB/41/01416089.html
