Installed DDE's. Moisture in pass side headlight
Installed them yesterday. All went well. I had to open the pass side Head Light twice. The first time I finished and as I pulled the dde wiring, the bulb fell off. Perhaps I did not put on enough epoxy. I left the DS headlight turn signal bulb out as HOUSECOR suggested in his write-up. Forgot to do the pass side. I washed her tonight, and saw moisture in the headlight.
Any ideas??? I pulled out the light to dry and noticed water on the ballast and by the HID plug. http://images.cardomain.com/member_i...70_54_full.jpg |
You could try leaving it out in a sunny area all day to see if that'll help. It didn't for me, so I just opened it back up, wiped up the moisture, resealed & used a small/thin amt of silicone around the seam of the headlight.
Did you use channel locks to assure a tight seal? If it's warm, you may be able to dry it out by removing the bulbs and sitting it out in the sun awhile.
guys thanks for the replies. i did use channel locks. the drivers side is fine. i left it with the fan blowing on it and it's now dry. i am concerned that it will get moisture in it when it rains again.
should i open it up and put more of the sealant on it?? anyone know from where can that be purchased? i really don't want to use any other sealant stuff. i already messed-up the tails by using the wrong stuff... |
housecor,
i did use channel locks. i noticed that the top part of the headlight did not sit in properly. when it rains, do you guys get water seeping to the back of the heads? i never noticed it before. when i pulled out the headlight, i noitced water on the ballast , and the pulgs |
housecor,
thanks housecor
After you seal them up again w/the OEM sealant, run a thin bead of clear silicone along the seam. It won't mess up anything, and if you ever have to re-open them, it won't be a problem as long as you make sure it's thin. I did..haven't had a prob. since.
thx |
| All times are GMT -7. The time now is 07:16 AM. |
