Brake light works intermittently
ok, I hate being the newbie, but I got a question on my newly purchased 2000 max --
The driver's side brake light is working intermittently. Running lights and blinkers are fine, but no brake light. Is this an electrical issue that Nissan needs to look at? Could it be a loose connection? (And yes, the bulb has been replaced) Has anyone ever heard of this? Thanks for your help guys! |
look at your wires.. or fuses
Might have a burnt out blub.
are those standard bulbs or upgrades? Is moisture getting in? The connector could be loose or getting jarred. Either that or what i'm really thinkin the bulb is bad.
Thanks guys for the replies. I need to just take a few minutes to check it out, but my baby's on the other side of the country :( (I'm on vacation)
Thanks again! |
I have a 2000 max aswell. I have noticed that my right taillight sometimes stops working aswell. I noticed it go out like 4 months ago, and only happened 1 time since then. I just shook the wire harness around until it started working and didn't touch it again. let me know what ur situation is. Probably a loose harness aswell. Just wiggle the wires and have someone push the brakes :nod:
Did you wiggle the connectors to the back of the tailight? I haven't gotten a chance to look back there but I highly doubt the actual wires are to blame. |
Originally Posted by zourtney
I'm glad I'm not the only who's seen this before.
Originally Posted by DanL
Once I bent the contacts back into place and reinserted the bulb, the problem disappeared.
© 2024 MH Sub I, LLC dba Internet Brands
