Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   Igor's rewiring fog with high-beam on (https://maxima.org/forums/5th-generation-maxima-2000-2003/245849-igors-rewiring-fog-high-beam.html)
Bl_asd Aug 23, 2004 02:17 PM
Thx to housecor, 've rewired my fog with parking light. Now i wanna do Igor's wiring. The problem is, I still not sure which wire I should cut. The white little connector ( the little one right next to light switcher for '00) has 2 wires. 1 is green and light ornage strip and the other 1 is green with yellowish stripe. i think i should cut the green with yellowish stripe. Need some confirmation before i do it. Also...which spot is the best for grounding...i can't get the bottom column cover off. it kind of stuck there...can i ground on any screw even it's not attached to metal?( i think not)
Bl_asd Aug 24, 2004 04:40 AM
need help...sry for the bumping...
2k2kev Aug 24, 2004 05:39 AM
Have you tried PMing him, rather than bumping this?
Igor911 Aug 24, 2004 06:19 AM
Are you looking for the same connector that I show in the picture?
http://memimage.cardomain.com/member...36_15_full.jpg
The wire on a 2000 is Green/Yellow. As for the grounding...you can either ground it to another ground wire or ground it to something in the steering column. And for the peice of dash u cannot take off, try to pull it a lil bit, sometimes it gets stuck.
Bl_asd Aug 24, 2004 07:05 AM
can i ground the wire to the wire right next to it(green/ornage stripe)? I mean..can i cut that wire and use connector to connect them all together?
Igor911 Aug 24, 2004 07:10 AM
I'm not sure dude. Just if you don't want to fry anything, please follow my directions. If not, your on your own. I took the time to research this correctly. 1 wrong move and you will break fuses and cause shorts or what-not
Bl_asd Aug 24, 2004 07:15 AM
Alright ,thx a lot i"ll see what i can do..
