rewiring how-to's...sorry
....first of all....i did try the search but to no avail..
....i even checked the how-to's but the only linked that seem to work was mingo's and the write there is very ***ue....and the other write up links did not work.... just wondering if some has instructions on how to re-wire thes side markers and fogs... ...also wondering if there were diferent ways to rewire the clears and fogs to ...ie to blink with the coners....or is that just it.... also ...rewiring the fogs....does what? thanks for your help.. |
the side marker re-wire link is dead on my computer as well, so i cant help you there...but i can tell you what the foglight re-wire is and that you should definitely do it! When you re-wire your fogs (2 min. job once you get the relay box open..), it allows you to turn the fogs on with only your clearance lights and sidemarkers, and not with your headlights...it looks very good and is definitely worth your time (since it takes so little) and money (since it's free)
That's basically the Org Signature........ here is the link to it..... made by housecor
Follow it step by step http://www.innerbean.com/housecor/fog_rewire.html |
This is what I used, worked like a charm: http://www.cardomain.com/member_page...=227798&page=5
Don't know if there are other ways to do it, but this way the blink with the signals when the lights are off, blink alternately with the signals when the lights are on, and stay on when the lights are on. |
| All times are GMT -7. The time now is 03:19 AM. |
