2k maxima w/ bose door speakers....
ok, i go on crutchfelds site and it gives diff options. all i need to know is if its 6 1/2 or wha. the front doors and the backs.
6.5 can fit both front and rears(allthough only the from OE is 6.5 , the rear is 5.25) the rears will require an adapter plate(alot of times crutchfields mention it comes with the speakers) and the fronts might require a spacer, depending on the magnet depth.i have 6.5s front and rear of my 2k W/bose maxima.......
beautiful, you helped me out big time. did u have to space anything out for the rears to take a 6.5?
nope in the rear they clear just fine. cause of the 1/2 window down feature maximas have, ugh.... my alpine type r 6.5s came with some sort of mounting bracket i was able too shave a little and made it match up too the original 3 screw holes used by the white bose peice
when u did ur hu n speakers, did u run ur own wiring to bypass the bose, or did u buy the adaptor?
i ran all new 16ga wire through out the car to the trunk ...only cause i was adding a 4 chan amp for the highs also. so it only made sense. but if your just gonna run them off a head unit it wouldnt make much sense too do it. just use the wire harness adapter.
hey your on the southflorida maxima board also right panda? this is 2000maximaSE
wassup man?u goin to orlando for the meet? |
if you want to go cheapo you can use the stock speakers as adpater/spacers. Just punch everything out of the middle and use the trim as a mount. Lot of 5th gen guys have done this.
© 2024 MH Sub I, LLC dba Internet Brands
