SES with no DTC's set?
Old Jul 26, 2005 | 05:39 PM
cgrubert's Avatar
I just finished a repair to my EVAP canister vent control valve. I had code 1448 saying that the valve was stuck open, so I looked at it and sure enough the piston was shot and it wasn't closing. So I replaced the control valve last night and reset the SES (through OBDII port). After about 200 miles the SES came on again. I hooked up the reader to see if something else was busted, but there are no codes set. The reader thinks the SES is off. So I reset it again. I'll have to see if this happens again, but has anyone ever seen an SES come up with no DTC's (either set or pending)? I have to get an inspection in the next two weeks so I need to get anything emissions related fixed, including the annoying SES. For an OBDII reader I use the Auto Enginuity connector and a laptop if that helps, and the car is an 03. Any ideas??? Thanks.
Old Jul 27, 2005 | 11:29 PM
cgrubert's Avatar
After resetting it again it came back on after a day. Still no DTCs show up. Also, the gas pedal method of resetting the ECU doesn't work anymore (at least when it's in this state). I have to use the OBDII interface. Does anybody know how to get into the Nissan specific information to figure out why this thing is upset??
Old Jul 28, 2005 | 03:45 PM
paralyse's Avatar
I Miss My Maxima
Disconnect the battery, leave it off for 24 hours. re-connect and perform the ECU reset and idle air volume learning procedures (use Google to search this forum for the procedures.) It's possible your plain-jane code scanner didn't properly clear the stored code registers.
Old Jul 28, 2005 | 07:03 PM
cgrubert's Avatar
Thanks, I'll give that a try.
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
