View Poll Results: VQ35DE ISSUES - Please place your poll
Voters: 839. You may not vote on this poll
POLL - If you have a VQ35DE please enter.
Originally Posted by SR20DEN
Then obviously the problem is not with the rings. It has to be with the valve seals, crankcase vent, or some other vacuum related part up top.
'02 w/87k km (50k mi) I've been using Mobil 1 5W30 w/Nissan filters since new. My car has always used a bit of oil, about 1 L every 5 km. In the last few months, it has not used a drop and I have no explanation. I do get the 1500-1800 rpm rattle when the ambient temperature is warmer (15C+), but in the winter it is not apparent.
Originally Posted by BewstAdd1ct
actually, its one liter per 3100 miles. and yes, thats about normal to me.
1 qt every 3k miles is not normal in a bigger picture. i dont think there are many new cars that come from japan that eat that much oil. maybe a few ounces every oil change is ok, but 1 qt every 3k miles is too much.
off topic:
if ssr can make a turbo for the 3.5 alti, why isn't there a good one for our 5.5 gen motors?
Originally Posted by Guerrero
I have an 02 Altima, single turbo VQ35DE and I haven't had any problems with the engine. I only have about 25,000.
02 Se
I have a 02 SE with 103k on it. I have had pinging for about the last 1500 miles, typically around 1500-2200 RPM or downshifting going uphill.
This morning, went to crank it and it started, then heard a loud "tap tap tap tap tap" noise coming from top end of engine. Plenty of oil in it and no SES lights. Taking it to carmax (crap) since it is still under warranty. Will see what they find out.
We're not talking about VWs here, we're talking Nissans. No VQ should be consuming half as much oil as that. If you're losing that much oil, there is a serious problem.
Says who?!
"Look at me, I'm Mr. Customer and i say thats too much oil, and I'm right because im Mr. Customer"
until nissan or another expert on the matter can give a spec for oil loss on a VQ35, no one can really say. obviously burning an amount that will affect engine operation in the distance traveled between normal oil change intervals is excessive. for the most part, 1 qt low doesnt seem to be doing that.
ya, in anything other than a graduated cylinder. like i said, normal to me
Originally Posted by GBAUER
One liter is approximatly one quart. So close that you'd never know the difference.
Says who?!
id say so, that'd put you at 6 qts in an oil change, which would deplete all of the engine oil way before interval, affecting the operation of the engine. yes, its excessive. is it an internal issue, or something else causing the problem?
how much is WAY more miles? what mods do you have? just whats in your sig?
you dont have to teardown the engine to locate the source of an oil consumption.
...I wonder if it doesn't have something to do with the secondary intake opening? Never really thought of that. Anyone know if that's possible? I haven't opened mine up yet to dig into it.
gbauer: sounds like you are the pioneer in resolving this issue. let us know if you find what's going on. i think a lot of people here are going to own their maximas when they hit 100k miles, and that seems to be when the oil burning starts. if it's the failing pre-cats, that's probably affecting our engines in much lower milage than 100k. i would definetely do some preventative maintanance on my car and fix whatever is wrong at 45k, than wait till 100k and deal with more issues that resulted from oil burning.
Says who?!
Nissan isn't likely to give a "spec" on oil loss. They're probably just as likely to give a spec on permitted power steering pump leakage or knock sensor failure. These things are problems, not properties that we should "live with". Healthy engines do not burn significant amount of oil. Burning oil can indicate other problems or problems that may be soon to arise, like a loss of compression (and therefore performance) or excessive valve train wear (and eventual mechanical failure).
If the precursor VQ30DE had ever seen oil consumption like this, than it might be expected. However, the precedent set by the VQ30DE is one of incredible smoothness, reliability and longevity. As I've mentioned before, I've actually measured the oil going into and out of my '96 and after more than 200,000 miles it only loses a few ounces over the course of 3,000 miles. Some of these guys are talking about using eight to sixteen times that much over a third the miles in a car that's half as old. That's not right.
Of course, I'm talking about stock or nearly stock normally aspirated motors here. An intake or exhaust shouldn't make a difference, but forced induction is a whole different story and can increase the likleyhood of several engine problems.
Originally Posted by MaxKlinger
Unless Mr. Customer is also an Engineer and knows better?
yes, id DEFINATELY call an intake a mod. theres no question about it.
I just rolled over 136k in my '03. It's an internal issue: I can see the smoke rolling out the back any time I hit 4k RPM's. No leaks anywhere. I'm tearing down the engine to do a little more than just fix it. I won't go into details yet, but it should be fun when I'm done. Only real engine type mods are the intake, cat and timing advance if you want to call those engine mods. I sincerly hope the problem is in the valves and not the cylinders.
ya, as soon as i read this post, thats what i thought. the pressure waves obviously change at the switchover point, im wondering if your problem isnt just a leaking i/m gasket or something of the sort. im not sure if the lower carries oil or not, however.
its good that youve made a project out of a small mishap. its a bit inspiring, and im sure youll have PLENTY of help from us, as well as your locals. im eager to see what you can put out.
40k on my vq35, and I'd say i'm burning about 1q every 5-7k.
Personally, I don't think this is normal for THIS engine. I have no engine mods, and I've owned this thing since new. It's not beaten or raced, but it's gets driven like it was designed to be driven. I have a 6 spd as well.
I switched to Mobil1 @ about 10k, and to my recollection, I did not start burning oil until about 25-30k miles.
I'm REALLY wondering if this is something caused by the Full-Syn blend???
I've always heard that switching back to dino is bad, but I'm thinking I might do it if this oil consumption issue gets any worse.
Again, this engine should NOT be consuming any oil under 100k miles, IMHO.
gr
gr
Just a little bit of information. I have this slight rattle and it seems to have gotten worse. Now when I am on the highway at about 40-60mph, with light pressure on the accelerator pedal, I get a constant rattle. It will only go away if I rev higher or back off the pedal. I have ran two full tanks of Shell V-power and it did not cure the rattle. I never checked for oil burning, but I'll take a peek today.
Ugh, hope I don't have a problem. I'll have to go check the level. I got some blue smoke out the back on a cold start the other day, which surprised me considering I've only got 38k on the engine. My other car with 58k hasn't done that.
Ok, so cold in CA is only 40F so far. Question then: are most folks on the west coast running 5/30 or should I use something heavier?
bought my car with 34,500 on it and changed to mobile one at like 36k. I checked it 2-3k later about (bit foggy on exactly) and it was low, burnt maybe like a quart+. But since my last oil change i really havn't had much of a problem, its been 2-3k, its burnt a little i think but not enough for me to worry. I'm putting royal purple in next and will see if it will burn that. It will be a few oil changes before im 100% sure if its burning or not
well i think i figured out why some people are have oil consumption issues. I was reassembling my motor today, i never took rings off pistons and what do i find but the upper/lower oil ring and oil expander ring are all inline with each other. they are supposed too be offset to eliminate possibility of oil blowby.
'03, Mobil 1 Syn. OEM filter. no oil loss, but timing chain rattle on cold starts
Our dealership has replaced 4 motors due to oil consumption since the 5.5gen came out. I checked with several other dealers when I had first heard about this and they all have had less then 10 cases each. What seems to be a big problem is the throttle blade screws. We have had over 30 motors replaced due to this problem (since 9/02), and it affected the p.finder, and altima as well.
Thanks Matt.
gr
recently i had my engine block changed by a nissan dealer for this issue of pinging or rattling in the engine when at 1800-2300 rpm's with a slight pressure on the accelerator. I am at 52,000 miles..i am going to bring it up to the dealer again..what could I tell him is the problem..?
It's looking like the rings are bad in the 3.5's. From the sound of things, Nissan fixed it in the 2k5 models. I'll be able to verify in a little while.
BTW I had an oil analysis done at 94,000 miles on our 2002SE by Blackstone Labs. I'll post the report when I figure out how. In the meantime, I'll quote their commentary:
"Whatever you're doing to keep wear this low, keep it up! The oil was in good shape physically, containing no moisture, fuel, or coolant. The air and oil filters are working well, too. Great engine!"
A report like the one that Blackstone puts out can help determine many different engine problems, and oil burning is definetly among them (fuel in oil, etc). In this one particular case, oil burning is not an issue.
I encourage everyone to have an oil analysis done (it costs only $20) to get some hard data about their engine health. I'm waiting back for the results on my '96, which has 222,000 miles. It should be interesting to see.
Originally Posted by elix
Over 84K miles. No engine rattles, no burning oil.
Those are predominantly highway miles with no mods.
Awesome, another '03 with over 80k miles like mine. The car might as well be brand new, thats how well it drives. Most of my miles are highway and 0 mods as well.
This has been a great read fellas.
Couple things that come to mind when reading...
1qt every 3k is considered normal by most manufacturers of high performance motors. The LS1, LS6, LS2 all burn about a quart every 3k miles. The LT1 burns roughly 1/4 to 1/2 quart every 5k miles.
Several are definately burning more than a quart, I wonder if any of this is blow by from high rpm? This is another thing thats fairly common on high performance motors. The Vettes, Fbodies, Mustangs and lots of other vehicles have this.
3qts every 3k miles is wayyy too much unless you just beat the **** out of the motor and really rev it. Even then it seems steep. But I do know some people that burn a couple quarts every 3k miles due to their driving habbits with their LS1 cars.
Just some thoughts
Just some thoughts
