What color is the TPS on the 2k2's; where is the ECU
Just like the title states, I am wondering where/what these things are. I am almost done installing my ZEX wet kit, but I need to know what color the TPS wire is. If you guys don't know the answer, then I need to know where the ECU is so I can hook the kit up directly to pin 73 (throttle signal). Thanks in advance!
EDIT: PIN 83 instead of 73. |
did domeone say TPS report? :wall:
Just to clarify, pin 73 is the accelerator pedal position sensor. The throttle position sensor is pin 83. I believe both those wires are white. Not sure which on is right for you, but 73 isn't the TPS.
I had a wiring diagram for my VAFC-II install that may help somewhat: http://forums.maxima.org/showthread.php?t=463936 And another that SR20DEN put together: http://vq35de.com:2002/A33x_ECM.pdf If you have a FSM, the ECU pinout diagram, descriptions, and voltages on pages EC-139 to EC-149 will come in handy for future reference. The ECU (and harness/pins) is on the passenger side behind and below the center console behind a black plastic shield: http://i11.photobucket.com/albums/a1...c/DSCN4506.jpg http://i11.photobucket.com/albums/a1...c/DSCN4507.jpg |
Yeah. Uh, did you get that memo?
Thanks so much, puppetmaster. I have that picture too saved on my computer. I didn't realize I put pin 73 until this morning. TPS=throttle position sensor.
sorry for the late reply man. i replied in your thread in the nitrous forum.
I got it working. I just t-tapped into into the wire that leads to pin 83. Works perfectly. The 75 shot is killer!
| All times are GMT -7. The time now is 10:28 PM. |
