Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   Sunroof Problem: Tilt up and down works, but sunroof won't slide back (https://maxima.org/forums/5th-generation-maxima-2000-2003/353919-sunroof-problem-tilt-up-down-works-but-sunroof-wont-slide-back.html)
Colossus May 12, 2006 10:05 AM
I had a remote start install a few days ago (by my brother) and ever since then, my sunroof won't slide backwords. It tilts up and down fine though.
Any ideas? I've tried looking a sunroof fuse and can't seem to find one.
Thanks!
2k2nismo.PL May 12, 2006 10:15 AM
try to bush the sunroof opening thing just a little back and if the sun roof moves at all push that handle forward and then back all the wayit should open it worked for me 2 times
djbonsu May 12, 2006 10:22 AM
try resetting/relearning the sunroof by holding either the tilt up or down(i forget which one it is) for at least 3-5 seconds. this should fix your problem. this can alsoo be found inside the manual for your vehicle. hope this hepls.
Colossus May 12, 2006 10:44 AM
Awesome! All I had to do was reset the switch by holding down the "tilt down" button for a few seconds.
Who would have thought that the manual held the answer? Thank you so much for the insight.
