5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
#3767
#3769
2. place new emblems where the old ones were
why do you want to remove emblems...but put new ones somewhere else
and why start a new thread when you could asked it in here
F'ing typical
#3771
remove emblems
1. heat up area with blowdryer
2. use fishing line to pop the emblems off
3. use hairdryer again to heat up sticky padding
4. peal off padding
5. use goo gone to remove anything left
#3774
To Nissan or not to Nissan
I need to buy a small suv for my son. I am looking at about a 2000-2002. and am considering a Pathfinder or and xterra. What do you think
-do these year models hold up well
- is there any problem with any of these year or models that i should be concerned with.
- what should i be able to buy if i wanted to spend under $7,000.
- should i be looking at outher models or suv's
Thanks for any help
Thanks for any help
#3775
Thanks for any help
Thanks for any help
#3781
i dont have a problem with your posts here...just starting the pointless opinion thread
remove emblems
4. peal off padding
remove emblems
4. peal off padding
#3782
you can fill in the holes if you want (i did that on my 00 on the right)
or just get a smaller flush mounted emblem like i have for my 02...maybe from a pathfinder
#3785
The problem you are going to have is the blue light you like does a horrible job lighting up the road, especially in the rain. There aren't any blue lights, legal or not that even give out light equal to stock bulbs.
You might want to look into the Osram Silverstars (the European ones). They aren't blue but they put out a really white light and a wide and long beam pattern.
#3788
help please! MAF? doesnt sound like it...
so i started the car today and it ran fine until about an hour later it just lost power, still running i have almost NO power and the engine just runs out of steam at around 4k. then makes a pretty wierd choking noise that sounds more metallic than anything else. this sound is right around 4000 rpm and i dont really try to push it any further but im pretty sure the engine just wont rev past 4k. the car has a really hard time accelerating anytime in any gear. i recentlyreplaced the MAF with an 01 and it ran until today (about 2 weeks later). also today was rainy and humid about 70+ degrees. i have no clue what this problem could be, no CEL and sometimes while driving down the road it wont rev past 2400 rpm. just dies. and when i pull over to restart it it "bounces" at 2400 rpm which as i understand is this engines "safety" when it gets an invalid signal from the MAF. can any one help me please, this is driving me nuts.i went out again and just now tried to start it and itll actually rev to redline now but its really weak above 3k, it also sounds alot different more of a hollow blaaaap sound instead of the grunt you usually get from the vq, when i first got the car 2500 rpm gave a nice growl, but now its like i have the growl throughout the entire rev range, just no hp... also i noticed upon startup there was a little rattle on the downrev ( not revving it high ) but it sounds like there are metal chunks in my cat or something...the engine doesnt do it at idle or while revving up... can anyone help me with this?
... yeah all three at the same time
#3789
almost like nismomaxm has in this thread http://forums.maxima.org/showthread.php?t=319047&page=2
unfortunately its an older thread and has been left unresolved
thanks everyone for your help in advance this website is a lifesaver
#3791
So my car throws a code. I go to Autozone and it's the P0113 code for IAT(Intake Air Temp). I got some advice to pull the MAF and try cleaning it. So I clean it this morning and while I'm in there I noticed that there is a wire "yellow with green stripe" just hanging there. Does anyone have any ideas or is good with wire/connector repair that can throw some advice my way??
#3793
help
anyone heard anything about what sound like metal flopping around in my cylinders closest to my firewall. it sounds like death, like the engine shouldnt even be running, loss of power, doesnt clunk above 3k. just around 1-2k rpms and when the engine is holding revs, also theres a fairly queit sound that resembles an exhaust leak when the engine downrevs... but the thing is: its not very loud like you would get from an exhaust leak, its very faint and you have to be stopped with the door open and your head leadned out to hear it. the CLUNKing sound immediately goes away when i let off the gas or get on the gas, it wasnt there before today. the power ALMOST (still would get smoked by an 4-gen max) came back and would finally rev past 4k when i cleaned the MAF sensor but theres 2 bad sounds, a horrible (probably an understatement) rattle, and at the same time the intake seams really loud, definately unusually loud and a different tone. Im short of thinking theres half a piston in there just flopping around only because the power it does give past 3k until it just dies in power at 5.5k even though noticably less is still smooth and theres no jerking or cut out... my oil level is fine, butterfly screws still there, no CEL.... im so lost, and broke, i have no idea where to begin...
Oh and sorry about posting twice ive just been driving the car on and off trying to pick up what that noise is after reading other peoples posts and every time i feel i have a little more info to try to help someone help me...
i replaced a toyota camry with this?
#3794
anyone heard anything about what sound like metal flopping around in my cylinders closest to my firewall. it sounds like death, like the engine shouldnt even be running, loss of power, doesnt clunk above 3k. just around 1-2k rpms and when the engine is holding revs, this sound immediately goes away when i let off the gas or get on the gas, it wasnt there before today. the power came back and would finally rev past 4k when i cleaned the MAF sensor but theres that horrible (probably an understatement) rattle, at the same time the intake seams really loud, definately unusually loud and a different tone. like theres half a piston in there just flopping around. my oil level is fine, butterfly screws still there, no CEL.... im so lost, and broke, i have no idea where to begin...
#3795
Sounds like a thrown rod. Hmmm, not common at all. Soundclips would help. Does it have oil?
#3798
and i dont know if you were askin me nmex but oil looks fine, had a change about 3 or 400 miles ago.
#3799
the car is stopped in a couple as i couldnt pick up the rattle from inside the car and when the camera leaves the tach i put it under the car outside the driver door. . theres a video of inside the car holdong revs, all the while the same rattle as heard in the others is ocurring. and theres one where i get on it a little to show it does rev and thats a stock airbox with the the front part removed, i wish i knew how to say it better, but theres plastic that looks like it's to try to scoop air from the front and reduce noise, anyway i took that off a while ago leaving the airbox with a 4x3 ish inch opening....its louder than before and a noticably different pitch
i also notice that when the engine is coming close to idle and the noise is about to go away which it does when i get on or off the gas, the rattle kinda breaks up and doesnt follow the beat of the engine. meaning like if it was a rod or something the rattle would slow with the engine but still be present at idle? and possibly worse at 5k? i really appreciate the help you guys... im going to bed its been a long day and i cant believe this happened at around 3pm today and its now 5 AM !
http://www.mediafire.com/?7tgehzj3lta
http://www.mediafire.com/?cg0zrmmmwzu
http://www.mediafire.com/?fylmjib5mzj
