Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   5th Generation Maxima (2000-2003) (https://maxima.org/forums/5th-generation-maxima-2000-2003-7/)
-   -   ventilation button led's burned out... (https://maxima.org/forums/5th-generation-maxima-2000-2003/372443-ventilation-button-leds-burned-out.html)
jettatdi Oct 17, 2006 07:22 AM
want to replace 2 of the led's that are burned out on my ventilation buttons, is this pretty easy?
PAREDLINE Oct 17, 2006 07:27 AM
mine are burnt out too. Just take the unit out and the back cover off and you'll see the bulbs. I just haven't gotten around to it yet.
upstatemax Oct 17, 2006 10:29 AM
It is pretty easy to replace them and it is cheap. Call the dealer ahead of time, most do not stock the bulb.
While you are in there, you night as well as replace them all.
BTW, is this an Auto Climate Control, or standard?
jettatdi Oct 18, 2006 06:16 PM
Its auto climate. Thanks for the advice. Little problems like this drive me nuts. Must be obsesive compulsive.
Matt_01SE_20th Oct 18, 2006 06:59 PM
You could always do what i did and turn them into LEDs, as they are actually bulbs from the factory. Much cheaper (~$8 per at dealer vs. about 25cents for the LED setup) More time though.
upstatemax Oct 18, 2006 07:10 PM
I got mine for $4 a bulb from the dealer...
LED's are also much more work and way to bright for me. I just happen to prefer the stock bulbs. :rollsmile
JiggaD369 Oct 18, 2006 08:33 PM
Any write-up's (maybe MetalMaxima) for switching to leds on standard control?
Atl92Se Oct 18, 2006 08:38 PM
and what size of leds are recommended and where to buy? radioshack or ebay? thanks.
crispykid717 Oct 19, 2006 05:18 PM
Anybody have tips on how to get the climate control out to replace the bulbs??
Atl92Se Oct 19, 2006 08:40 PM
how about this:
http://forums.maxima.org/showthread.php?t=471588
BigFly_2K2SE Oct 19, 2006 08:55 PM
Or this..
http://forums.maxima.org/showpost.ph...&postcount=132
I just did this....it's not a total cakewalk if you're not experienced, but not too bad. The biggest PITA is all of the wiring harnesses plugged into the back of the console that need to be unplugged to get it out and then plugged back in.
