Brake system Flush
I am planning on doing a brake system flush at the same time i upgrade to my Altima Se-r brakes.
I was wondering how many bottles of brake fluid would be sufficent to flush the system. i am thinking of using ate super blue racing fluid. |
Originally Posted by Zack342
(Post 6426567)
I will be doing in the same in about 2 weeks. But i will use Motul.
Originally Posted by RacerX1320
(Post 6426589)
(Post 6426589)
"Friends don't let friends, drive stock"
I bought 2-3 cans of ATE Super Blue, but only used around 3/4 of 1 can. And that was flushing each corner several times.
You should bleed your clutch fluid while your at it. It also uses brake fluid
If you didn't get them yet I HIGHLY suggest speed bleeders. They allow ONE person to bleed the brakes and you can do it in about 15 minutes. (with the wheels on or off).
They kick a*s. I have them on my car and moto. http://www.speedbleeder.com/ |
Originally Posted by foodmanry
(Post 6429201)
They kick a*s. I have them on my car and moto. http://www.speedbleeder.com/ for the front i'd just turn the wheel, but im interested in the rear. |
Originally Posted by Kevlo911
(Post 6429073)
(Post 6429201)
They kick a*s. I have them on my car and moto. http://www.speedbleeder.com/ Maxima 84-97 SB1010 SB1010 - SB7100 |
Originally Posted by UGAd13
(Post 6434142)
What size did you get? On their website it only lists the following for the Max:
Originally Posted by kgallerie
(Post 6434168)
I asked the speedbleeder guys that same question a while back and they said the SB1010's are the size for the front and rear for my '03 maxima.
Originally Posted by maxximaa
(Post 6429600)
how do you do it with the wheels on? jack up the car is the only thing i can think of, unless u got a 3 spoke rims.
for the front i'd just turn the wheel, but im interested in the rear. Get some clear polyvinyl tubing to slip over the nipple of the speed bleeder with the other end going into a waste container. Just loosen the speed bleeder 1/4 to 1/2 turn. Watch your master cynlinder to make sure you don't empty it. Periodically check the clear tubing for air bubbles. Usually about 5 or 6 pumps on each caliper is good enough. |
I like these speed bleeders; might get some for my I35 and Chevy P/U. Do you have to do anything to the ABS when bleeding the brakes?
Originally Posted by Malibu Jim
(Post 6439188)
No. ABS is just a sensor, don't touch it. |
....it's personal preference, but unless you guys are doing track days or VERY aggressive street driving -- racing brake fluid is TOTAL overkill.
You're basically buying yourself a higher boiling point. SHop wisely! Btw -- tell me more about the SE-R setup. Haven't read much about it yet...what's it include/cost?? gr |
I use a one man vacuum canister bleeder from griot's garage and it's awesome! No compressor needed, just pump it up and open the bleed screw and open the vacuum valve... This is really fast....Just watch your reservior fluid level!
Originally Posted by ghostrider17
(Post 6441057)
Btw -- tell me more about the SE-R setup. Haven't read much about it yet...what's it include/cost?? |
Originally Posted by NmexMAX
(Post 6443822)
It's identical to the 6th gen upgrade, minus the differently shaped caliper and lettering on the caliper. All else, (rotor size / thickness / pads, etc) are the same.
(Post 6443831)
Is it direct bolt on or do you need an adapter plate?
i know the 6th gen is discussed many times.....but the SE-R?
edit: found some info....my apologies..... |
© 2024 MH Sub I, LLC dba Internet Brands
